Fuji FinePix S7000 Digital Camera
Problem for Fuji FinePix S7000 Digital Camera
Optional DC Battery Pack Use
By JazzyMike on Jul 10, 2006
I have purchased an optional external battery pack for the S-7000 and the camere worked fine until I used the battery pack on another device that required the polarity on the tip to be reversed. When I went back to using the battery pack on the S-7000, I forgot to switch the tip polarity back to positive and now camera does not work with the battery pack.
I was told that there is a diode that blows when the polarity is reversed that prevents futher damage to the camera. I work in the electronics field as a repair technician and I would like to fix this because I'm sure I'll forget to swith the polarity back and blow the diode again. Where can I find a service manual for the FinePix S-7000 and are parts available for this camera?
Thanks,
JazzyMike
Best Solution
posted on Jul 11, 2006
Helpful)
bmwrider
Rank: Wiz
Rating: 84%, 1893 votes
Bad luck mate. It's easy done, I did the same with a $35,000.00 Camera. Only once though :-)
You're right it should be diode protected but the diode doesn't always help and a good circuit will also have a fuse in line. Take the camera apart and find out where the power leads actually enter the PCB. Somewhere very close to that will be the diode obviously marked with a D prefix eg. D1001 or D101. Check to see if it's open circuit and if it is replace it. Be careful if it's a surface mount component, it's easy to damage the board.
If by chance the diode has gone closed circuit (it's possible) then it would take the fuse out as well. Look for a component marked with an F prefix. Sometimes the circuit board will have a warning about replacing the fuse with the same value component. This will give you an idea where it is on the board.
Sometimes a manufacturer will use a fusible resistor in the power section but I haven't come across a digital camera with one of these yet.
Now for the bad news. Occasionally a diode will blow closed circuit and then blow a fuse. Alhough it all happens in milliseconds it's possible it didn't happen fast enough and taken out various other components with ICs at the top of the list. Hopefully in your case this hasn't happened. I wouldn't fancy having it on my bench if it has :-)
Oh! you might even have to check for burnt PCB tracks as well.
BMW
Was this helpful?
Yes
No
Solution #2
posted on Jul 21, 2006
Helpful)
rafiq
Rank: Wiz
Rating: 79%, 61 votes
Thanks for contact us.
Mr.JazzyMike
As u described, i think there is serious problem in your camera.I suggest as follows
* If you are familiar to open the camera,safely open it.
* safely discharge C612 located on power/flash board.
* Then safely pull out power/flash board from the chasis.
* Then check fuses no. F 500,F 501,F 503,F 504,F 505, F 506 if any of them found blown replace it and then go back.
SAFETY : TAKE SPECIAL CARE OF CONNECTORS AND FLEX PWB. Dont use external battery pack for any digital camera.
If you are not succeed contact us.
mail us : cam_tek@sancharnet.in
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
scrajmer
Rank: Wiz
Rating: 81%, 500 votes
It is strange to hear
" I work in the electronics field as a repair technician and I would like to fix this because I'm sure I'll forget to swith the polarity back and blow the diode again. "
Anyone having a little knowledge would not attemp to give power supply to any device in the wrong polarity. So chances of doing it again and again is really strange .
Anyway, it is true there are safety fuses in the power section of the camera that blows off in case of any change in the supply. Sorry I do not have the service manual. If you happen to find one pls share it with others also. you can search for the fuses manually by keenly observating the power board of the camera.
Was this helpful?
Yes
No
Solution #4
posted on Oct 21, 2007
Not Rated)
stachy
Rank: Apprentice
Rating: 0%, 0 votes
try the http://www.partstore.com/ they carry several million parts and had sony tech manual, not inexpensvie though..
Was this helpful?
Yes
No
Popular Solutions for Fuji FinePix S7000 Digital
Questions and Unsolved Problems for Fuji FinePix S7000 Digital
Do you recommend Fuji FinePix S7000 Digital Camera?
Answer
Answer
Cannot view objects in iew finder/screen - they are all squiggly colors like green and purple.... (More)
Answer
View screen is jumbled and will not focus with a clear image.
Answer
The screen gradualy went white with no picture on display or images. Where can I get it repaired?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fuji FinePix S7000 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
