Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Sony WEGA has multicolered vertical lines
When I turn the TV on it warms up slowly (2-3 minutes) then the entire screen is covered with thin multicolored vertical lines. Occasionaly it will actually come on like it's supposed to though.
I've heard that it could be the Q-Box. Is this true? If so what is the Q-Box, how much does it cost, and a fairly technically savy person replace it?
  • 5 more comments
  • eeeerock Oct 21, 2008
    Thanks MisterSony. If the computer does successfully come on, I think the OSD/Menu works. I'll have to try it. However, when the vertical lines are showing, nothing works at all.
  • eeeerock Oct 22, 2008
    Thanks mistersony. I tried to get the "normal" screen to come up last night, but didn't have any luck. I still get the vertical lines, and of course the OSD doesn't even show up. I'm willing to tear into this thing in an attempt to fix it. I won't be out much being it was given to me from my brother-in-law (and yes he did indicate it was broken).
    So if you don't recommend that I go into service mode on the unit, what do you think my best course of action is?
    Thanks MisterSony. I'll give it a shot this evening and get back to you. FYI, I'm in the process of acquiring a service manual. Hopefully it will help as well.
  • eeeerock Oct 28, 2008
    Mistersony,
    Sorry it took me so long to get this info back to you. I've been traveling since late last week. When I went into service mode. I got the following info displayed on the screen during two different trials:
    PANEL NVM OK 0 OP
    0 NV_CC 204 Diff 1
    WEM2 SERVICE
    0 DCP - INT
    0 DENC 1
    NVM = OK NVM - VER = 0006
    Any ideas as to what it all means?
  • Any Guy
    Any Guy May 11, 2010
    So what you are saying is that sometimes it comes up and the menu/osd works, but sometimes you get nothing but the colored lines. I would almost have to put the set in service mode when it had the colored lines to be sure it was not a block problem. It could be the Q-box, since the OSD graphics are generated in the B board and then fed to the Qbox where is eventually gets to the display. By putting it in service mode you could display the panel test patterns and at least verify that the block was OK. You could also use the Qbox patterns and see if they work. Before you ask, No I don't recommend you get into the service mode. The reason being, you need to know the service menu pretty well to navigate the service mode when you can't see anything but colored lines on the display. It's much easier when the Test Mode graphics can be read and I would be willing to walk you through it, but with only colored lines, it's a bit too complicated and very easy to mess up something. Sorry!
  • Any Guy
    Does the OSD (on screen display work? Or the menu?
  • 320 Answers
OK, much as I have reservations, let's try service mode. To enter service mode, you MUST have the original Sony remote. You need to press these buttons in order, with the TV off. You have about 2 or 3 seconds to complete the series of buttons. Press:
Display
#5 (the 5 on the number keypad)
Vol + (volume up)
power
Then, after the screen is lit, press the "jump" carefully 3 times. If the word "penle appears in the upper left corner, the optical block is OK and it's probably a Q-box problem. It COULD also be the LVDS cable that sends the signal to the optical block. If you press anything else, IMMEDIATELY TURN THE TV OFF AND START AGAIN. The TV should reset to the original values.
Posted on Oct 22, 2008
  • Any Guy
    Any Guy Oct 22, 2008
    Be sure to rate the help I have given you
  • Any Guy
    Any Guy Oct 28, 2008
    If you got that information to display when you were getting the multicolored lines problem then you have successfully eliminated the optical block as the source of your problem. It's now probably safe to assume that the Q box is the source of your problem. Be prepared: the q-box is usually a very expensive part, though not as bad as the optical block.
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Sony wega kde-61xbr950
Can be a problem with a misplaced connection, more likely the Ysus card to be replaced.
Aug 30, 2008 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
1. My Sony KP-57WS500 TV is turning blue after abut 3 minutesof operation. It stays that way for about 30 miunes and comes back with pictures again, but with predominatly blue color. 2. Sometimes the TV...
Sounds like the picture tubes are failing,common on sony. do you notice any thin horizontal lines? You mite get lucky and be able to adjust the voltages. Remove back cover and look inside to see which tubes are lighting up.The front panel below the screen will come off and behind it is a small access cover.remove it. there you will find the voltage controls (its a plastic square with 6 knobs). 2 knobs for each tube, 1 is focus the other is the voltage labeled "screen". they are marked so look closely. Green is always in the middle but sometimes they flip the controls for red and blue so pay attention to which you are controlling .slowly adjust screen voltages to see if you can get it to stay on. If you over do it those thin horizontal lines will pop up and the tv will shut off again. If you already have lines back off the voltage by turning knob to the left slowly until they diappear. If that seems to fix it but the problem but it comes back later, then the tubes are shot. good luck!
Jul 05, 2010 | Sony KP-57WS500 57" Rear Projection...
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Aug 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blue Vertical Lines on the screen
It means the optical block is going bad. Contact Sony support. They will sometimes warranty these even after the 1yr warrany has expired. Have your model and serial numbers handy.
May 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand wega KDF-E50A10
unfortunately the B Box assembly needs to be changed in these and price of the part alone is more than half the cost of a new tv
Apr 10, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
283 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
