Question about Singer 7462 Mechanical Sewing Machine
Adjust timing on Singer Merritt 4530
Help! I'm trying to finish my daughter's Halloween costume and my bobbin thread isn't picking up. I've deduced that it is a timing issue (thanks to breaking a needle). I can't find my manual anywhere!
Can anyone give me SIMPLE instructions for adjusting the timing on this machine?
Thanks, in advance for your help!
  • Gra6J Jan 02, 2009
    I have tried every which way to get it to sew and my only other option I think is to set the timing. As of now it will not even make a stitch. i hope that you could help me with this problem.... Jan Grant
What size replacement needles for a singer merritt 4530
Posted on Nov 15, 2008
HELP PLEASE!!!! Need to figure out how to fix a Singer's Sewing Machine's drop in bobbin casing for my Singer 90s Special Edition???
Sounds like bird nesting or thread nesting (a user error), where there are thread "barfs" under the fabric. This is caused by the top thread not being seated in the tension disk. Remove the thread from the machine. ALWAYS RAISE the presser foot when threading the upper thread!!! Rethread from the beginning. Verify the thread path is correct. Set the upper tension at the midway point between high & low numbers--you'll probably need to tweak it for your particular machine.
Remember, when experiencing problems, install a brand new needle. Remove the thread from the machine, RAISE the presser foot, and rethread from the beginning.
It also helps to always pull the bobbin thread to the top of the fabric, gently hold both thread tails in your left hand, and then slowly take the first couple of stitches.
Understanding Thread Tension Threads
Mar 10, 2017 | Singer Sewing Machines
Hello I have a singer futura 2 920 everything
relax and start over. make sure the bobbin thread is alright and the bobbin is put back in properly and try again.
Oct 17, 2014 | Sewing Machines
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
How to thread Singer merritt#9608? Probledm with birdnesting
what size bobbin and do you have pictures to show how to thread 9608 singer machine
Mar 10, 2012 | Singer Sewing Machines
What is the secret to getting the bobbin holder back into the singer merritt 4530?
I have trouble with this every single time. What you need to do is remove the silver plate right under the needle. If you think of the case as the number 6, put the comma I just typed (a little piece of plastic sticking out from the rounded section at the bottom) under the metal at the bottom.
Then slide the metal plate at the top back on. You may need to turn the knob on the side of the machine (that makes the needle go up and down) to get it to go back on. At this point, as you're turning the knob, the bobbin case should fall back into place.
I just finished doing this myself. Now my issue is that the thread from the bobbin keeps knotting up.
Oct 24, 2010 | Singer 2932 Mechanical Sewing Machine
How do i thread my bobbin on my singer merritt 4530
Run the thread around the little silver knob on the top of the machine to the bobbin threader on the top right. Wrap the thread clockwise around the bobbin a few times and then pull the bobbin threader toward the silver bar. If you put your hand on the crank wheel, you will feel a place for your finger to set. Push there and the center of the crank wheel will sideways allowing you to thread the bobbin when you press the pedal. I'm sure my terminology doesn't make any sense.
Jul 11, 2009 | Singer 7462 Mechanical Sewing Machine
Singer/merritt 2430 bobbin fill
If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
Jun 18, 2009 | Janome 6019QC Mechanical Sewing Machine
Singer 626 Not sewing
First, give Mom all your Reese's Peanut Butter Cups.
Then, be sure the bobbin-winding function is not still engaged. Check it again, since on some machines, the mechanism has to be backed off until you hear a click, or until a light turns off. If that's done, check the tension on your top thread, since that's easier, then on your bobbin thread.
If the bobbin didn't get wound evenly (Like if you're hurrying) that will mess up its ability to let the thread flow out, so see if the thread on the bobbin looks as smooth as a new spool of thread.
I hope you got your costume together & had fun aside for that frustration. :^)
Oct 29, 2008 | Sewing Machines
How do you thread a singer merritt 4530 sewing machine
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Jul 14, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
2,079 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
