Question about Acer AL2032WD 20" Flat Panel LCD Monitor
Acer AL2021 My monitor works as it is supposed to when turned on, after it has been on for some time, and the computer is rebooted the start up ACER logo flashes on then of after a second or two and the screen remains blank. If I shut off the power for 10-30 minutes the monitor works again and will remain on and work well unless rebooted. Any suggestions what causes this or how it may be repaired. Thank you
  • 2 more comments
  • acbko mou Jul 11, 2006
    Sorry the model number is AL2021 not 2032
  • Torin Walker Sep 12, 2008
    One year after purchasing this monitor, I ended up with the same problem. The monitor would turn on, flash the logo for a brief period (~200ms), go blank, flash the PC screen (also ~200ms), then go blank. Not even the monitor's menu would show when the menu button was pressed.
    I used to be able to fix the condition by unplugging it for a few seconds, then turning it back on. Recently however, a reboot has caused it to go into this failure mode, I fear, forever.
    I tried all combinations of holding keys down, cycling the power switch, even unplugging it. Nothing it seems can ressurect this monitor. I have yet to remove the cover to see what lies beneath.
    If anyone knows which part in the power section happens to be faulty (or even has a suspicion), I would appreciate the info. I would also appreciate greatly receiving a PDF of, or a link to, a (free) service manual for this monitor, if such a document exists; I could then attempt to repair the monitor and post my findings for all.
    Torin...
  • Faubut Oct 26, 2008
    I have the same problem with my son's screen and I only bought it for him 2 months ago. It only flashes the logo and then it goes black. I tried everything I know how to do and could not fix it. I am very very disappointed.
  • Anonymous Nov 11, 2008
    Did anyone ever resolve this? I've had the same problem intermittently with my AL2021 for a couple years. It has recently become much worse--every day I have to hit the on/off button under the monitor dozens of times before I get lucky and it comes on. I've made several calls to tech support over the past two years, and no tech has yet acknowledged that this is a recurring problem with this model, though I've found several mentions of it on the web. I'm finally sending it in for repair.
This also worked for me, On the monitors power supply board, i replaced 2- 470uf 16v, 2-1000uf 16v and 1- 680uf 16v capacitors with ones which were 25v and the monitor works awesome now! Pretty good for a 4.51$ fix and free monitor.
Posted on Jul 10, 2011
  • 3 Answers
I fixed my AL2021 by replacing the output caps on the power board. $4 repair. Pull the thing apart and replace the 1000uF, 680uF and 470uF caps on the end of the power board.
Posted on Jan 17, 2011
  • erik_321 Mar 31, 2011
    Replacing the capacitors worked for me too.
    If your screen suddenly goes black a lot of times just the backlight goes off. You can check this with a flashlight by shining on the screen and watch carefully if you see anything. If you can see anything your monitor is still working only the backlight has failed.
  • leetaylor425 Jul 10, 2011
I had exactly the same problem with my acer al2021 - they replaced the power unit and now it's happening again - first the flickering and now no picture at all! and their repair warranty is only 3 months... they told me it would be cheaper to buy a new monitor! so i will - but never another Acer product!
Posted on Jun 19, 2007
A TV repair shop can repair for about $50 -replace one of the transistors on power board
Posted on Feb 19, 2007
My acer AL2416w monitor turns on to a black screen
I have 2 Acer AL2416W monitors that i have been using for 2 years. There has been a handful of times i would turn my computer on in the morning and the screen would be black and Acer would lightly flash on the monitor 1 time. Typically a restart would take care of the problem. Last week the monitor blacked out and i can't get it to work. Any suggestions?? I switched ports on the computer to verify it wasn't the video card and tried new DVI cables to verify it wasn't those? Is this fixable??
Sep 06, 2009 | AcerView 77E 17" CRT Monitor
Acer ZG5 lsass.exe Part 2
you need a bootable image on your flash drive. if you ve just copied the cd files the USB wont do a thing and the monitor will keep blinking. what is the exact problem?
Jul 24, 2009 | Acer Computers & Internet
It is all black, as if off
when starting windows press f8 key before the windows logo shows up > go to safe mode > click start>control panel> display>adapter>list all modes> choose 800x600 x 16 colours > apply > close > reboot to normal xp. OR When f8 key pressed > choose VGA mode. If this does not work then change the VGA Cable (borrow from someone if its TFT to test)
Jan 05, 2009 | Acer AL1717 17" LCD Monitor
Acer AL1912 Monitor - Screen to black and light on yellow
I found some solutions other posted that didn't come up the first time I looked. I did a reboot and I'm good to go!
Dec 07, 2008 | Acer Computers & Internet
Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
Oct 03, 2008 | Computers & Internet
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1714
OK I have the same monitor, I was given it by a client when I couldnt fix it, I DO have the 19V supply and still getting the same problem.
If you open it and reseat all connections you can reach, I find it starts to work. Unfortunately after less than a few days use it goes off again.
Hopefully this can help someone get further
Apr 14, 2007 | Acer AL1714 17" LCD Monitor
Acer AL2032WD 20" Flat Panel LCD Monitor Logo
1,486 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
