Im getting a blue shadow .i go in to the digital array i cant get the blue to move up or down but it moves left & right what can i do
  • 3 more comments
  • mrchevelle67 Oct 21, 2008
    how can i fix it not able to get the blue to move up or down it moves left & right the red will move up & down left & right
    I didnt recilicone anything.
  • mrchevelle67 Oct 22, 2008
    Hitachi model# 50fx20b i am confused is it ic or the lamp the only work ive done on this is go into the digital ray to adjust the color crosses the blue wont go up or down
    How do you reset your projector default setting.
    where can i buy the resistors
    Sergeant:
    Champion:
  • 435 Answers
Enter the I2C Service Menu, be sure the power is OFF. -On the front control panel, press and hold the INPUT button. Then press the POWER button for two seconds. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
- Before continuing further, Confirm that R, G and B drive are set at 40.  - Be sure to press SELECT after each change to SAVE the new Data.
- Use the Remote Control Joystick to scroll down to next page until 'LCD Adjust' is highlighted.
- Move the joy stick to the right to cursor right once. The next page will appear with the word 'Ghost' highlighted.
- Cursor right again, and a white screen will appear with a Black Square in the center. You will see LCD Adjust, followed by 'SHP' and some number/ value.
- If the unit is out of adjustment, you should see a gray ghost on either side of the black square. - Move the joystick to the right or to the left til the ghost disappears. The number values will change up or down.
- If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.  - If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.  - Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
Press the 'Exit' button thrice to return to normal picture.
It should work now ...
Found this in fixya ...
Posted on Oct 22, 2008
    Genius:
  • 1,226 Answers
did you really troubleshoot your TV.? .If yes then you should test the component of the horizontal and vertical projection. that maybe loss connection in it. try to re soldered all the parts since it was functioning that's only minimal errors in it.
melnavz
    Genius:
  • 1,030 Answers
The symptoms you describe tells me it is a resistor in the blue convergence output the fact the blue still moves in one way tells me that the ic is still working these resitors are ussally next to convergence ic the convergence ics are two big black component on heat sinks. if you can find the open resistor ussally value around 2.3 ohms 1/2 watt.
  • 905 Answers
This the conversion IC STK that controls the vertical horizontal and color alignment
this is common repair in all projection tv's
you can check this site click here and cross reference your STK
electech
  • 4 more comments
  • jason Oct 22, 2008
    you should replace the convergence IC ecspecialy if there is a bad resistor there
    any electronics parts supply store , they can also get the STK IC
    if you reset the tv , you will have to realign ,and that won't help when theres a problem exsisting
    I go to a couple of stores called RS electronics and Bursma electronics but I'm sure your names will be different , but just look in the phone book or online for a parts store near you
    this is I belive your stk click here
    nad yes there are two stk's in the conversion and thats why you will have to find the bad resistor , but when you do the conversion replace them both because half a tune up won't last!
    Genius:
  • 1,913 Answers
Reset your projector with defauts settings.
Posted on Oct 21, 2008
  • 507 Answers
It's time to replace the lamp
  • 94 Answers
On the blue crt below the glass tube you will fine two metal tabs. By sliding the metal tabs (they move in a circular pattern) you can re-center the crt with a little experimentation. Then follow the convergence procedure to complete the repair. When you resiliconed the anode lead you may have moved the metal tabs from their previous position.
    Genius:
  • 1,550 Answers
You need to provide brand and model number .
    Scholar:
  • 136 Answers
It is the problem of convergence setting or convergence IC.
50FX20B- I am trying to allign the digital array and cant get the red to move,how do I move it? (the blue WILL move)
Please replace convergence output chips in tv to solve the problem. It requires good soldering skills/ expertise and click to buy convergence repair kit for this tv that has all required parts and instructions.
Hope this will help.
Thanks.
Jun 11, 2011 | Hitachi 50FX20B 50" Rear Projection...
Multi-point convergence -- Lower left quadrant of screen distorted. Red ok. Blue arched up and then done to normal in Lower right quadrant; left-right adj moves vertical gridline but is s-shaped. Blue...
Look in users manual or internet you should find how to access service mode, this is different from regular setup CONVERGENCE, this involves getting into changing parameters to tweek convergence, even after amps are changed. These projection tv's are known for loosing convergence if bumped, moved and amps go bad in time.
Jan 03, 2010 | Pioneer PRO-520HD 53" Rear Projection...
I can't align red or green bulbs with the digital array, how can I get them to move left/right they only move up/down.
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2009 | Hitachi 50UX57B 50" Rear Projection...
Can't get the blue and red box to align
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 25, 2009 | Hitachi 50GX30B 50". Rear Projection...
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
Convergence problem
You need to replace both convergence ICs number STK392-110 youcan get replacements at the following link and they provide free installation instructions with pictures so you can do the job yourself . heres the link.
http://servicemanuals.vstore.ca/
May 04, 2008 | Toshiba TZ50V51 50" Rear Projection...
Digital Array?
Replace IK04 and IK05, both STK392-110, but use instead STK392-150's for greater reliability. And don't get some Chineese knock-offs - use original Sanyo replacements. If you don't know where to get those try ACME Enterprises in Florida,
http://www.acme-sales.net/index.shtml
Also measure the low ohm feed resistors in that circuit. However usually just replacing the convergence amps will restore normal video...
Bill
Nov 17, 2007 | Hitachi 43FDX01B TV
Shadow problem
Im sorry i dont understand what you mean"I have a shadow on my picture"??? Please be more discriptive? Thanks . Maybe a picture of it??
Jun 27, 2006 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
