Question about Linksys WRT160N Wireless Router
No CD, no instruction, not very good with computer, pls help
1 month ago I bought a linksys WRT 160 N router. I installed it, following the info and with the CD. Now suddently, I can not get any signal on my laptop anymore and I just found out that by mistake we trought away the box with the instruction and the intallation CD. How can I re-install my router if I do not have the key code and the information and the CD. I am not very good with computer. Pls help me
Thanks
Jocelyne
  • Linksys Master
  • 6,487 Answers
Since you don't have the setup CD of the router the only way to make everything work here is to manually reconfigure the router by accessing its setup page that is inside the router where you can do and reconfigure the router back and if you're not aware on how to do that you can contact Linksys tech support to walk you through with the process they are open 24/7 this is the number 800-326-7114 call them anytime....
Posted on Oct 21, 2008
Client Mode or 2nd Wireless Router with new Subnet Mask?
The original firmware does not have this option, but you can get a custom firmware at http://www.dd-wrt.com/
DD-WRT is not supported by linksys, so a little caution there as this could ruin your router if it is not installed properly. Fortuately they have plenty of documentation on installation and troubleshooting if needed.
Also found this on how to setup Client Mode through DD-WRT - http://www.dd-wrt.com/wiki/index.php/Client_Mode_Wireless
May 20, 2012 | Linksys WRT54G Wireless-G Broadband Router...
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
I am currently using a Linksys BFR series router that works fine. I am trying to replace it with a Linksys WRT 300 N router. I go through the installation program provided by Linksys on my HP computer...
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | Linksys WRT300N Wireless Router
Marius asking Cannot connect internet to laptop Pro with Linksys WRT 160 N
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 12, 2010 | Linksys WRT160N Wireless Router
BRIDGING MODEM AND ROUTER
Your firmware may not support bridge mode, try installing dd-wrt from http://dd-wrt.com/dd-wrtv3/index.php
Aug 19, 2009 | Linksys Wireless-G WRT54G Router
I bought a Linksys wireless G-WRT54G Router. When I purchases it I was told this was all I needed and how easy it was to set up. I have no idea what I am doing but I can not get it to work. I have a...
Other than the laptop and the LinkSys WRT54G, you would need an active account/subscription with an Internet Service Provider (ISP) who then will provide you with a modem of sort.
On initial setup, connect your modem to your laptop and verify that you can connect to the Internet. Thereafter run the CD installer that came with the LinkSys before connecting/powering the LinkSys. Follow on screen instruction. At one point in the installation, you would be asked to disconnect the modem, connect the router and connect the modem to the router.
Should for some reason the above instruction will not address your concern, pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | Linksys Wireless-G WRT54G Router
Internet connection
1st check your cable with the tester 2nd configure your router then the last configure your connection go to control panel then network connection then right click local area connectn then properties one click internet protocol tcp/ip then properties check obtain IP add automatically then obtain DNS then start to connect again
Mar 27, 2008 | Linksys BEFSR81 Broadband Router with 8...
Need the driver for Linksys WRT300N V1 ... can't find the CD
The LINKSYS WRT300N is a standalone device, there are no software/driver needed on your PC for the router to work. However, there is an easy Setup Wizard that is in the CD that normally comes with the unit.
Unfortunately, Linksys did not make the specific Setup Wizard (Version 1.3) for the WRT300N available online. However, if you care to try the Setup Wizard for a WRT54GC, it may downloaded from the LINKSYS ftp site here. I used to have a WRT54G and I did make use of the Setup Wizard for that model. I upgraded to WRT300N. The setup wizard for the old WRT54G worked likewise on the new WRT300N.
Alternately, the WRT300N can still be configured without the CD or the Setup Wizard by logging into the Configuration Page (192.168.1.1). Remember to use LAN interface when setting the router (as shown in the connection diagram) and set your PC to an IP Address of 192.168.1.2, Subnet Mask of 255.255.255.0; Follow on screen instructions and enter settings/configurations manually.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information. Additionally, if you still prefer to have a copy of the original WRT300N Setup Wizard, pls include your email address that I may send it to you as an attachment.
Nov 24, 2007 | Linksys WRT300N Wireless Router
Linksys WRT160N Wireless Router  Logo
277 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
