Question about Toshiba Satellite M45-S2692 Notebook
Need help i have a toshiba m45 laptop. when i shut it down it wont shut down i have to hold down the power button to turn it off and then i cant start it right back up i have to wait awhile.
I am trying to reset my toshibe m45 s165 to its factory settings, but when i try the whole press "0" and power at the same time, the laptop keeps turning off since im holding the power button,...
Do not hold the power button down while pressing the "0" key - it'll shut the computer off again. You just need to push it once to turn the power on and then hold the "0" key immediately after you push the power button on - just like turning on the laptop, but this time you're holding the "0" key down.
Feb 05, 2011 | Toshiba Satellite M45-S165 Notebook
My M45/S331 doesn't start nomally
its happen because you left it and it was overheat pls take care your laptop work or keep in cool place while working.
Jun 10, 2009 | Toshiba Satellite M45-S331 Notebook
Will not shut down
you can go to the control panel, find power options, and than set how you want buttons to react.
Jun 01, 2009 | Toshiba Satellite M45-S2653 Notebook
Toshiba Satellite M45-S265 PC Notebook power on button
when did this start
maybe you just need to clean around power button
built up dust and dirt can cause this to happen
Feb 14, 2009 | Toshiba Satellite M45-S265 Notebook
Dead Toshiba Satellite M45 S-169
hi dear
maybe you can try to check your memory module
release your memory module, use am eraser to cleaning your memory. and install it again
Mar 23, 2008 | Toshiba Satellite M45-S169 Notebook
Shuts down unexpected,
Sounds like an overheating issue, I would suggest using a cooling pad.
325aed8.jpg It's a simple device, you just rest your laptop on it and the fans do the work.
Sometime they overheat when working in a confined space, make sure you have ample room aroung the laptop for ventialtion.
Hope this helps
Mar 07, 2008 | Toshiba Satellite M45-S169 Notebook
Computer got stuck
Long press the power button until it shutdown.
and then restart, if the system failure to start tell me what happen i will tell you the solution.
if the system start scan the system with antivirus. here some online scan that are verygood.
may this help.
Feb 04, 2008 | Toshiba Satellite M45-S265 Notebook
My toshiba laptop will not turn on...
Here is the fix my toshiba laptop also wouldent turn on so i call them and here is what you do 1. unplug the laptop
2.take out the battery 3.hold down the power button for 20 seconds (doing this drains any excess power fron the unit) 4.put battery back in 5.plug in laptop 6.try to turn it on
hope this helps
Jan 05, 2008 | Toshiba Satellite A60 Notebook
Open Questions:
BSOD when trying to install Win XP, or boot Win XP from hard drive BSOD screen is as follows: A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: The BIOS in this system is not fully ACPI compliant. Please contact your system vendor or visit for an updated BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable the ACPI and allow you to continue your installation. Technical information: *** STOP: 0x000000A5 (0x00000011, 0x00000006, 0x00000000, 0x00000000) Every BSOD I received was this exact code. I ran a RAM test with memtest86+, it showed 0 errors. I tried reinstalling BIOS v 1.1 (supplied by Toshiba) and the first time it did let me boot into the XP Home installed on the system, after which it worked fine. While in xp, I checked device manager to see if the system was ACPI, and it was. I've also tried BIOS v 1.2, the last one supplied by Toshiba, to no avail. I did try pressing F7 during one of the installation attempts, and it hung at "setup is starting windows", I tried pressing F5 during an attempt, and there was only one option besides "other", the typical i486, which I selected, after which it hung at "setup is starting windows". I've flashed BIOS with v 1.2 a few times now, with same BSOD during both xp install attempts and boot attempts. What baffles me is the errors did not show up until I tried to install xp for the first time. Before that the computer booted every time. I've never heard of xp effecting BIOS during install. I have been to the microsoft support page for this BSOD. There are two articles on this specific code that I found, one for a "wake from hibernation" error, and the other for an xp installation error, seems as though the latter applies here. URL below. I'm fixing this for a friend. I fix computers all the time. This one is getting up there with DELL's laptops. The screen is broken, so I'm using an external monitor. He doesn't want the monitor fixed, so I'm only doing a fresh install + Backup for him. Thank god I already backed up the data. Thank you in advance for your time. (I just got the error again. Gonna try windows 7.)
Jan 21, 2013 | Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite M45-S2692 Notebook Logo
145 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
