Question about Konica Minolta DiMAGE G400 Digital Camera
My pictures are really bright or completely white
When I take pictures they are coming out completely white if I am outside or in a bright room. If it is a darkly lit room the pictures have lines through them.
  • 215 Answers
Sounds like a major problem and not one which could be tackled on line. If your camera is still under warranty, return it quickly. If not I hope you have deep pockets. You are suffering from either a faulty iris control or faulty video board. With perhaps a little CCD problem to help things along.
Posted on Jul 12, 2006
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
Pictures are over exposed when outside
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside.
Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight
t
Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Samsung Digimax L60 Digital Camera
Why does my camera take white pictures outside,
Do you have the ISO set to a very high number instead of "auto ISO"?
Apr 18, 2010 | Kodak EasyShare C763 Digital Camera
LCD screen and pictures go completly white
The camera is defective. But as you've only had the camera three months it still is under warranty. Canon is usually very responsive to these type of problems and will bend over backwards to make things right (probably the most responsive of the camera companies).
Call 1-800-OK-CANON to resolve this issue.
May 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Video is too white/bright outside. Can see nothing but white on v
I can not use my camera when taking pictures outside .it just shows up too bright. I don't know what I did as I have taken picture before.Can someone tell me how to find the correct setting menu?
May 07, 2009 | Olympus Camedia C-770 Digital Camera
Blurred picturs and real bright!
CCD failure u need to go to casio for free replacement
u dont need reciept ur warranty is valid with casio just go to them directly where are u from tell me i will fwd u link for that
Apr 10, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Ideal settings for Samsung LN-T 4234H
sure, lcd tvs need to be tweeked depending on the light in the room the darker the worse the picture. so try this
from standard:
picture: 85 to 95 %
brightness: 45% or adjust the black of the video to the black of the pilar bars to equilize them.
color: 32 to 38% or until the flesh tones are not so hot
sharpness: low 10%
tint: always to center
color temp: cool1
back lamp ( if avalible) low when lights are dim, high when lights are bright.
the problem with LCD is they don't look so good with dark sceens. the contast ratio is very low. natively 3000:1 aas compaired to plasma or other direct view TVs. the LCD is back lite and the thin materal of the LCD can not completely block the back light from coming thru. there for the complete "black screen" is illuminated "blue". the best thing is to keep the lights on bright in the room for the best picture.
Feb 22, 2008 | Samsung LNT3242H Television
Pictures with White Lines
Same problem with mine!  Fine Any suggestions?
Oct 28, 2007 | Casio Exilim Zoom EX-Z700 Digital Camera
White lines, all white pictures
I have the same problem have you been able to fix it ?
Sep 23, 2007 | Pentax Optio M20 Digital Camera
Konica Minolta DiMAGE G400 Digital Camera Logo
108 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
