Kenwood krf-v5030d amplifier not recieving remote control signal or intermitently when tapped amp remote works turn off amp remote dosnt work tap amp again works
  • rossyg Apr 04, 2009
  • 298 Answers
SOURCE: Onkyo TX DS575x reciever remote problem
You might try this replacement
Posted on Nov 17, 2007
  • 1512 Answers
SOURCE: Marantz Amp
hi, well done in diagnosing your problem:) From what you have just told me, the amp has noisy source selector switching, and may even have more than one switch or control causing the problem. Start with the source/direct button.
To resolve this, best bet is to "flood" the internals of the switch or control with CRC 2-26 . This will clean the contacts and leave a layer of lubricant to prevent the problem reoccurring, Getting the spray into the controls is the hard part. Check out what you find by way of entry points that you can get a the delivery straw into to spray. Sometimes you can use the a hole on the top of the switch, or "click" the top of it a little, enough to get the sray in. If the switch is a hermitcally sealed type, i have in the past used a pin vice and a very small drill to make a hole at the very back of the switch creating a place to get the spray in. Check it out and see how you go.
Posted on Mar 29, 2008
  • 4234 Answers
SOURCE: Purchased vintage KENWOOD AMPLIFIER KA-6000.
I believe that that model uses coupling caps between the fron end and the final stage. Check those as well.
Posted on May 05, 2008
  • 3 Answers
SOURCE: Amplifier main channel non operational.
first pull out the power transistor then biased the output terminal. base,emitter have dc volts .4 to .5 collector to emitter have full voltage. if this voltage are in ur pre amp buy new trasistor
Posted on Sep 22, 2008
  • 6 Answers
SOURCE: Kenwood VR 209 Reciever, Remote Problem
this worked on my kenwood vr-209. 10 others fixed their kenwood as well from the posts.
Posted on Jan 18, 2009
Kenwood krf v5300d
I'd Google "Kenwood KRF V5300D remote control". Surely you will find a replacement available from someone. This worked for me to find one for a LG BluRay player.
I found them in the UK for example, at
Oct 13, 2013 | Audio Players & Recorders
How do I hook up a pioneer dynamic expander ex9000 to a kenwood KRF-V7030D receiver?
• Pioneer EX9000 out to Kenwood V7030D play In
• Pioneer EX9000 in to Kenwood V7030D rec Out
• instruction on page 8 of the manual
PDF] KRF-V7030D KRF-V6030D KRF-V5030D KRF-V4530D
Jul 31, 2012 | Audio Players & Recorders
I have Kenwood AV Receiver KRF-V5030D how can I connect EQ??? Has I am problems getting it to work
Any digital AVR can only support external analog sound processing gear (eq, tape decks, etc) for analog sources. As soon as a Tape Loop is activated any digital source will be disabled. Nature of the beast.
Jun 30, 2011 | Audio Players & Recorders
Hay mate i have a kenwood krf-v408od and i dont have the remote. just wondering if i can turn the loudness and dolby digital on without the remote?
Loudness: page 19 = Remote only.
The Input Mode key (page 8) selects how input signal are detecetd and handled. DD is NOT something YOU decide on. It is either in the signal or it isn't.
As far as getting the remote goes. It's an RC-R0626. Hit the Search Engines and find one.
May 31, 2011 | Audio Players & Recorders
Need a new remote control KRF-V4060D
You can order a replacement remote on the link below.
Good Luck and please rate 4 thumbs up.for the free answer.
Apr 29, 2010 | Kenwood KRF-V4060D Receiver
Hi i have a krf-v5030d and i am having trouble woking out how to connect it to my panasonic 37'' plasma th37px70b and my sky plus box can you help me please .thanks john
Hi John,
I have the same amplifier, a Sky + HD box, an LCD TV an surround speakers. We wont go into the Wii, PS3 and PC also hooked up. Essentially the best way to go (whatever you connect up) is to split the video and audio signals.
Sky: The Sky box has an audio outputs (left and right channel) found at the back of the box. You get some twin audio cables, plug into the back of the Sky box and the other end into the Kenwood Amp (for example we use Video 1). This means that the sound from Sky can be found on Video 1 on the Amp.
You take the video signal (picture) from Sky using a SCART cable and put into the back of your panasonic TV. This does mean that you can watch a picture without the sound and listen without a picture. The Amp remote controls the sound, the Sky / TV remote controls the picture.
You may need to tinker with some settings on the Amp, for example on the front of the Amp you will find a source button, toggle through the 3 or 4 options to give you the right sound. But essentially that should be it. The same process is used for any other things you want to add, like a DVD player, a games console and so on.
Hope this helps.
Regards, Mohammed
Oct 05, 2009 | Kenwood Audio Players & Recorders
Sep 09, 2008 | Audio Players & Recorders
Kenwood kr-v9020
You should find out who does the service for your reciever in your area. This type of fault can get fairly involved. It will require trouble shooting and then ordering the necessary parts.
The fault can be the motor, or the electroncs in the servo drive amplifier for the motor.
Jerry G.
Jun 10, 2008 | Kenwood KRF-V5060D Receiver
Kenwood control amp KC-206
Sounds like a low voltage to the front panel as the indicators are there such as control window illumination is dim and the remote does not function.
The remote sends an invisible signal to a detector just behind the front panel and if the signal from the remote is nice and strong from your new batteries in the remote then it must be the panel electronics.
I have found that if you clean the output panel of the remote with a damp cloth and the same to the front panel glass you may be lucky. Just Damp please not dripping in water!!!!!
If ypu keep the amplifier system very clean then this wont be the problem...But this action has worked on TV's with remotes...
If this doesnt work then a service is quick fix..
Oct 26, 2007 | Audio Players & Recorders
267 people viewed this question
