Print cartridge will not install on HP LaserJet 3800n
After replacing the black cartridge on my HP LaseJet 3800n, I get a message on the printer display 'black cartridge not installed'. I have taken it out and back in and it did not help.  I don't know if it means any thing to the problem but I notice a small black plastic piece that looks like it might be out of place but i don't know if that is so or where to put it without causing possible harm!  Any suggestions?
  • bpegram Oct 21, 2008
    waynechurch,  thank you for replying.....your comments are a relief!  But how can I get the cartridges to sit properly in order to be recognized by the printer?  The black plastic piece (one on each of the black and yellow cartridge slot) are just hanging there, but I'm not sure where to try to place them back at or if these black pieces need to be replaced by a service tech.  Please advise......
  • 300 Answers
Common problem on the hp lj 3800, you'll notice if you shine a torch in the area where you found the broken pieces of plastic, there will be some more, it is this which is stopping the toner cartridge from sitting properly in the printer. Don't worry about the broken plastic the printer will still work ok.
Posted on Oct 21, 2008
  • wayne churchill Oct 21, 2008
    Remove the plastic pieces but leave the wires there, it won't harm the printer. There is a repair kit available from HP, but you would require an engineer to fit it and to be honest the chances are it will just break again.
HP color laserjet cp2025 will not print. Help.
No.
Very few printers will print if they're out of toner, even if the colour toner is exhausted and the print job is only black. Replace the empty toner and if this is the only problem, the printer will continue printing.
Jan 20, 2015 | HP Laserjet Cp2025n Printer
Need default printer driver for color laserjet 3800n for windows 7 32 bit operating system
The Windows 7 has a compatible driver for many teams, try your printer is a greatadvantage when connecting it almost immediately begins to install. And do not waste your time searching for drivers on the network, there is little to W7
Apr 23, 2012 | HP LaserJet 3800n Printer
Can I make convert my HP laserjet 3800n into a 3800dn so i could print double sided automaticaly ?
You will need to buy a 'hp color laserjet auto duplex unit' to effectively turn your 3800n to a 3800dn and change the printer onboard controller but cost would probably more than buying a newer model with automatic double side printing support ... It is technically possible but I would not recommend it.
Sep 24, 2011 | HP LaserJet 3800n Printer
The far right hand side of pages printed on my HP Color LaserJet 3800n are faded .. as though the toner is not distributed evenly .. I've tried shaking the black cartridge but this has no effect .. can...
From the control panel, go to diagnostics menu and then select PQ pages. This will print color diagnostics pages so that you can see if it is one color or all colors that have a problem. If one color then it is either the cartridge or the scanner. If it is all colors then it might be the high voltage board, or possibly one bad cartridge causing a voltage drop. If you recently changed a cartridge put the old one back in and try a test print.
May 17, 2011 | HP LaserJet 3800n Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
I have a 3800n that the print quality is very poor-meaning the background is gray streaks where the paper should be the only thing you see. Making the paper look dirty. hope that explains things. this...
You can try changing the print density under print quality in the control panel. YOu can also check the reset to factory default and see if this helps. It could need what is called a maintenance kit where the fuser and rollers are replaced. I install these all the time and sounds like this is what you need.
Mar 19, 2011 | HP LaserJet 3800n Printer
HP color lasejet 5550 dn does't print. Is this message: 10.00.03 supply Error memory. Can you help me Thank's
hello
You could try with different cartridge try to clean the contacts , check wether the cartridge is seated properly , make sure weather the strip is removed from the cartridge
OR
If you use a HP original cartridge, then you shouldn't have this message.
Anyway you can print, it's only at startup that this message appears.
If it is a HP toner, then change it.
Or
try this link and you will find answers for all your printers errors
http://www.all-laser.com/cgi-bin/webc.cgi/error-code.html
Mar 05, 2010 | HP LaserJet 5550 Printer
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
Error message 10.92.03 in hp 3800n
Yellow cartridge isn't seated correctly. After reseating it and it still gets the error, try swapping the yellow and black cartridge. If the error changes to 10.92.00 then the yellow is bad. if the error stays the same...something is broken, probably the "cartridge lock" for the yellow.
Dec 19, 2009 | HP LaserJet 3800n Printer
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
341 people viewed this question
k24674
