Question about PfaFF Tiptronic 2030
When trying to sew with my PFAFF 2030 (NEW) the thread bunches up under the material. I have tried ajusting the tension many time but still does it.
  • engineers2 Oct 30, 2008
    That sounds like the same problem Iam having on my 6230. I have posted a similar question looking for answers...
  • Anonymous Mar 14, 2014
    tension
    Scholar:
  • 41 Answers
The thread bunching under the fabric is generally an indication that the upper thread is not seated properly between the tension disks.
  1. Completely remove the thread from the machine/threading path.
  2. Raise the presser bar lifter to the up position. This releases the tension disks, ensuring that the thread will seat itself properly when you again lower the presser foot.
  3. Rethread the machine, including the needle.
  4. Grasp the thread at the spool and where it comes out of the needle. Give it a little tug and "floss" is through the thread path - as you'd floss your teeth back and forth. You should feel tension on the thread.
  5. If you feel no tension/pressure on the thread, double-check to make sure the thread is between the tension disks (not outside of them).
  6. If thread is seated properly between the disks and no tension, there may be a mechanical issue that is causing the tension disks to not close properly.
  7. Also make sure the bobbin thread is turning in the proper direction and that the thread tail is under the tension of the bobbin case.
Hope this helps - don't hesitate to respond with further questions. We're always happy to help.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
Pfaff 3.5 was working fine,suddenly thread is bunching/getting caught under plate.Thread goes around the bobbin ok,when gets near to needle gets stuck on hook on right side.Any idea how to fix please?
Just guessing. You might try :
Installing a brand new needle
tightening the top tension a bit
If it continues to be a problem, most likely the machine is out of time and requires adjustment. Search for sewing machine timing or take it for service.
Apr 24, 2017 | PfaFF Sewing Machines
ChaMy pfaff 2144 will not stitch properly; pools masses of bobbin thread; Changed thread, tensions, needle etc still wont sew, please advise as I am so desperate to fix this problem
bunching of thread under material is a needle tension problem
tighten it up
proper tension is when it requires a small amount of effort to pull the thread through the needle eye
Jul 28, 2016 | PfaFF Sewing Machines
My machine bunches tread on the bottom of the fabric when sewing. What am I doing wrong. This machine is new to me.
thread bunching under material is an indication that the needle thread is not at the correct tension
tighten up the tension setting until the result is where the both treads meet at the center of the materials being sewn
practice on pieces of scrap until you get it right
Oct 01, 2015 | Sewing Machines
I suspect broken threads are trapped inside the thread route in the tension mechanism. Can I open and clean out?
I suggest turning the tension down to zero and using a crisp dollar bill to try flossing the tension disks. You can also try using un-waxed dental floss to try to floss out the trapped threads.
Feb 13, 2015 | PfaFF Tiptronic 2030
Help trouble-shoot jammed machine
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Also could be a timing problem, and the machine would need to be checked.
Sep 08, 2013 | PfaFF Tiptronic 2030
I have a pfaff tiptronic 6230 and the thread keeps bunching up under the material when i try to sew could you tell me what the standard settings should be to do a straight stitch. I have the G button down...
Hi Kathi it soulds like your not geting the thread in the tension unit.
Try this, thread the machine all the way to the needle but not in the eye.
Lift the presser foot up and down and pull on the thread at the same time.
You should feal the thread tension when the presser foot is down and not tension when it is up.
If this is the case then try and sew, if not then its not threaded right or your machine needs adjusting.
For were the tension dial should be set, I would put it on 4-5 for straigt and 3 for satin/button hole.
Apr 04, 2011 | PfaFF Tiptronic 2030
When I try to use the embrodiery unit the thread bunches up on the underside of the material--it is very loose. Any ideas on what is wrong?
The tension on the bobbin (under the deck) needs to be right. When you load the bobbin, try and pull out the thread a little. It should be firm. You should have to pull a bit to get thread out. If not, the tensioner on the bobbin is set wrong or has backed off (Or you loaded the bobbin wrong) Don't use the bypass slot!
There is one screw on the side of the bobbin holder, where the thread is pulled through when you load the bobbin. This screw can be adjusted to control the tension. See pfaff page on bobbins
Apr 21, 2010 | PfaFF Creative 7570
Pfaff 1475 tension problem.
Many users also reported similar bobbin tension adjust problems. But do you know it can be fixed by yourself? I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Jun 21, 2009 | PfaFF Tiptronic 2030
Pfaff sewing machine
You don't have the thread in the take up lever or it is not in the tension. Rethread it , Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.
set your tension to 5 and try it.
sewman7
Jun 17, 2008 | PfaFF Quilt & Craft Pro 7530
Thread bunches under the material
There ARE still parts for your 7570 - amazing how rumors can get around!
Could be any number of things - from something as simple as a thread caught somewhere in the upper/lower tensions to the tension assembly to timing to any number of other things? You may have already tried some of these - hope this helps:
  1. Try "flossing" your upper tension - this is nothing more than running a heavyweight thread (such as upholstery or 12 weight thread) through the threading paths. Grasp the thread at the beginning of the threading path and the end coming through the needle and "FLOSS" (back and forth - just like you do your teeth). This will usually pull through anything that is gently stuck.
  2. Pretty much the same thing for the bobbin thread - if you're comfortable doing so, loosen the tension screw on the side of the bobbin case to make sure there aren't any little bits of thread fuzz stuck under the tension plate on the side of the bobbin case.
  3. Also remove the needle plate to allow you to better see the upper part of the bobbin system - if there are any bits of thread, etc. stuck in there, you may be able to see them and pull out with tweezers (turn machine off before you do this so the tweezers don't accidentally come into contact with anything).
If this doesn't work, you'll need to have a sewing machine tech look at it (I would recommend a Pfaff-trained tech as they're going to be the most familiar with your machine). The 2140/2144/2170 use most of the same parts - even the new CV still uses some of the same parts.
Good Luck,
Kim
Apr 11, 2008 | PfaFF Creative 7570
Sewing Machines Logo
292 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
