Question about Canon PIXMA MP780 All-In-One InkJet Printer
Colors stop printing
I have an MP 780, that started not printing magenta. I tried a new cartridge, and eventually replaced the print head. It worked for a few days, then did the same thing. I complained to the company that sold me the new print head, so they gave me a different one. Again it printed fine for a day or two, and now it doesn't want to print cyan.
If I deep clean a few times, it starts to come back. I really like the printer, I hate to buy a new one (esp. after purchasing a new print head for it!) It is a few years old however. Any ideas?
  • thedousman Oct 31, 2008
    Thanks for the 2 solutions, sorry I am just now responding. I didn't realize anyone answered me -new to this forum!
    A couple of things I have discovered. Up until now I have been cleaning the cartridges off of the front panel. I noticed that if I go to properties (within the printer software via the control panel), there is a "deep cleaning" option. If I do this, the colors are 100%. But it doesn't last too long.
    This may be a dumb observation but...I'm wondering if the fact that have been refilling the same cartridges with ink since new, has anything to do with this? The cartridges are Canon, but the ink isn't. There's really nothing to wear out in the cartridges, but maybe they clog somehow?
    Thanks!
  • 2,427 Answers
Hi !
Sorry for the late reply but it seems as if its eighter the cartridges or the print head, seeing as you purchased a new print head , Are you using compatible Ink Cartridriges ?
I would suggest replacing the inks and cleaning the print head manually !!!!!!!
1.) remove the head
2.) soak some alcohol or menthylated spirit through it until it runs out clean
let dry and replace.. I personally believe the cartridges you are using are good!! the ink is too thick and fouls up the jets in the inkwell..
Posted on Oct 25, 2008
  • 76 Answers
It could be down to the cartidges, if they are non canon orginal this could cause the fault, if they are canon cartridges it could be down to the purge unit no working corretly,
i know you have spent money already but it might be wise to spend 130 english pound with a years warrenty from canon and buy a new machine.
I hope this helps
Posted on Oct 23, 2008
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
PRINTER (not web camera!) HP Deskjet 712c Printer began printing mostly blackPrinter began printing mostly black & magenta so I replaced the color cartridge. Color did not improve and then black...
First run the CLEAN HEADS and see if that helps. If you don't use your printer at least once a week the Print Heads get dried out and will not allow the ink to pass through to the paper.
Go to control Panel and click on Printess. Then when the window comes up, CLICK on Properties TAB and then in the next window, CLICK on CLEANING.
You may have to replace your PRINT HEAD if that doesn't work.
Hope this is of some help. Bud
Feb 06, 2010 | Computers & Internet
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
Won't print black ink text; looks like faint watermark print; ran all maintenance check several times (nozzle checks, etc)
Remove the black cartridge and soak it with an alcohol free window cleaner soaked paper towel let it sit on the towel for a good thirty minutes then wipe clean and put back in printer run nozzle check if necessary.
Oct 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
Won't print black ink 3E
I got a paper jam while printing.Know my brother mfc-290 will not print black
Apr 25, 2009 | Office Equipment & Supplies
Cannon Pixma MP 780
your MCY (color) cartridge is damaged, or either needs cleaning, try to remove this and clean the head with a soft cloth and re-install once again, if it doest work then replace the cartridge
Dec 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Sep 26, 2008 | Canon I900D InkJet Photo Printer
Canon MP 730 prints wrong color tones
I was having a similar problem-- what was happening was the print cartridge head seemed to be letting the colors leak into each other. (the science behind this is beyond me!)-- I noticed that instead of being cyan/magenta/yellow, my yellow cartridge had actually turned green, magenta was picking up blue and was turning purple, etc etc. I ended up replacing the printer's printhead and all the color cartridges and then it worked.
You can order printheads online.
Not sure if this fixes the original reason why they got all mixed up in the first place-- if the printer will continue to allow the print head to leak the colors into each other-- but hopefully that's a fixit!
Aug 10, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
153 people viewed this question
old marine
old marine
