Question about Toshiba MV20FL4 20 in. TV/VCR Combo
A black box pops up on the screen and just leaves the border area around the box available for viewing. It only happens on a few channels at a time and seems to alternate as to what channels are affected, i.e. it used to be on the weather channel all the time, but now that channel is fine and ESPN and Fox News are have it. It appears to be like a pop up window, but the window is solid black with no wording on it. Other than that, the TV works well.
  • 374 Answers
MRS3309,
It sounds as though the closed captioning has some how gotten turned on. Not all programs are closed caption supported so the box will not show on every channel nor will it necessarily be on the same channel all day. Go into the menu on the tv and ensure the CC option is turned off. You may have to go into set up or preferences to locate the CC portion of the menu. I hope this assists you and thank you for using Fix Ya. If I can assist you further please let me know.
Posted on Oct 21, 2008
Black border with some channels
if you mean the left and right sides of screen, look for a button on remote might be labeled several things, like picture size, aspect etc.. the borders pop up when you go to a non high def channel. some chs put borders all around the picture in those cases you won't be able to get rid of those.
Apr 07, 2010 | Memorex MVDT2002 20" TV
Black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Jan 26, 2009 | Mitsubishi CS-40307 40" TV
Red Vertical Burn Line on LCD Screen
Try changing the picture setting on the television rather than from the picture box.
Sep 09, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Black area on screen,
Hi omsoc,
This could possibly be an issue with closed captioning. While some closed captioning is a marquee-type text near an edge of the display, your television may have an option turned on to display a different channel of captioning that would likely display a large black box on your screen if there is no data to display. This would explain why this would take place suddenly at the same time each night, as well as why pressing the display button would cause it to disappear. I suggest you look into your menu to try turning this option off, then watch the channel you normally watch at this time. If this does not resolve the situation, I recommend you contact your manufacturer’s product support line.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 27, 2008 | Televison & Video
Vertival Color Lines
We had the same thing happen to us on the right-hand side. A technician told us yesterday that the Motorola Cable Box (supplied by Shaw Cable) places a border on Non-True HD Channels. Because we didn't place our picture setting to 'full-screen' each time we viewed these channels and burn line was created. He gestimated a replacement screen runs about $800.00 Canadian, but we have a 3 year extended warranty and will receive a new TV. He also said it happens on all big screen tv's that use a cable box creating borders on Non-True HD Channels.
May 04, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Black box showing up while viewing DVDs
This sound like a problem with the Closed Caption, on many sets if the C.C. is set to text a black box apears, and since it only happens on DVD you might look at the DVD menu and see if it has this Text featcher in the Closed Caption menu and turn it off
Feb 13, 2008 | Televison & Video
A black box appears on the screen
Just happened to see your black box problem associated with your T.V.; Thought I would pass along an idea for you to check into, and let me know if it helped...Check into whether or not it has a onscreen text block mode, if it gets into this mode by accidentally pressing the wrong buttons on the remote and or TV, it could and I have seen, at least with zeniths, a big black box which will cover the whole screen except for a 2 to 4 inch border around the box and outer edge of the screen...if this is the case, find someone familiar with the correct setting for the set associated with this problem, and get it back into the right mode....Hope this helps..T.
Jan 15, 2008 | Haier 20" TV/DVD Combo
Black screen keeps popping up
If a black box appears on the screen, and a small amount of the picture is visible around the border, it means that your closed captions are on and set to TEXT. Go back into the menu, navigate to the closed captions page and set the captions to OFF.
Sep 02, 2007 | Toshiba 50A50 50" Rear Projection...
Black borders
Check the resolution settings on your cable box, you may have to call your cable provider to find out how to get into the settings menu, there is a stretch function in the settings that should make all the lower channels auto fit your screen, also see if there's a p=size button on your remote control, try pushing that when on the channels that have sidebars.
Oct 26, 2006 | Samsung SP-S4243 Television
Toshiba MV20FL4 20 in. TV/VCR Combo Logo
619 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
