Question about Sony VAIO PCV-RS720G (027242658103) PC Desktop
No sound on Sony Vaio rs 720G after installing new hard drive
I have video but no sound
Had total crash and replaced Hard Drive
did I lose my sound when I did this? I am a novice.....
  • 749 Answers
Here is the link to the drivers http://esupport.sony.com/perl/swu-list.pl?mdl=PCVRS720G&UpdateType=Updates
check em all out in your device manager (start-settings-control panel-system-hardware tab-device manager) look for things with yellow ! or ?'s next to them. You may need more drivers than you think.
Posted on Oct 21, 2008
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Sony vaio crashed/ logitech
Hard Disk about to fail
This warning means the hard disk will fail sometime in the near future. You need to back up your data regularly before the hard disk fails or you will lose your data.
When the hard disk fails, you need to replace with a new one and install Windows on the new hard drive to get your laptop working again.
May 11, 2013 | Computers & Internet
VGC-RA830G No Boot/Post/Video/No Solution HELP!
Hi elmaflow
Have you installed an operating system onto the hard drive? If not then you will need to. Hope this helps.
Feb 15, 2013 | Sony VAIO VGC-RA830G (27242667815) PC...
How do I replace the hard drive on my sony Vaio VGN-NR120E?
To replace a hard drive, you'll need to backup any data you want to keep, uninstall the old hard drive, install the new hard drive, and then restore the backed up data.
The specific steps necessary to replace a hard drive differ depending on the type of hard drive you're replacing.
Jun 20, 2011 | Sony VAIO VGN-NR120E/S Notebook
I have a sony vaio pcg. it powers on and does nothing else. the 2 little cooling fans come on but the hard drive doesn't run and screen won't come on. can anyone help me out. thanks
Its possible that you already have a bad hard drive. It may have crashed. Your system will not boot without the hard drive running. The computer will keep on trying to look for the Hard drive that's probably why it looks like its doing nothing. Bring your machine to sony and have them fix it. If you know how to open up your Vaio, try to check the Hard drive connection and see it its loose, if its not loose. its time to replace the hard drive.
I hope this helps. Thanks and have a nice day.
- HotRatchet
Dec 14, 2009 | Sony VAIO PCG-K35 Notebook
Sony vaio laptop unable to detect new hard disk
Try connecting the drive to another pc with a usb adapter, create a partition and format it. Then put the drive back in the vaio and reinstall windows. This should fix the problem.
Aug 09, 2009 | Sony VAIO TR1MP Notebook
Hard Disk Crash
If you have replaced HDD of your machine, then there is no otherway to get your things back rather than installing them. If you have CDs from Sony, then you are safe.
May 13, 2009 | Sony VAIO PCV-W500GN1 PC Desktop
Computer crashing message at start up
If it's telling you that you're about to lose everything on the disk then you should probably buy a new HDD!
You can get a 500 GB HDD for about €50, which should last you a fair while.
Don't waste time or you may irreplaceably lose everything you have.
When installed get everything copied over to the new hdd straight away
Apr 19, 2009 | Sony VAIO Digital Studio PCV-RZ14G PC...
Operating system not found media test failure will not reboot aspire 3680
hi..try to remove unplug or plug in the Hard Drive,, if cant work you or nothing happens you need to re-place the hard drive.about files theirs nothing ways to recover the files if the Hard Drive is totally defective..Thanks..and GOOD LUCK...^_^
Jun 15, 2008 | Acer Aspire 3690-2196 Notebook
How to replacy its harddrive
It is pretty easy to replace a lappy's hard drive.. ensure you get the right one... Then it is simply matter of releasing & removing the Hard Drive from the laptop and then simply "Plug In" the New HD. After this it must be "Formatted" "Partitioned" and have the "Operating System" installed.. ya good to go. A service manual would also help.. I think I have found one below.. fileshare.eshop.bg/index.php?what=search2&searchstring=Sony+Vaio+GR+Series+Laptop+Disassembly.htm
Sep 03, 2007 | Sony VAIO V505DX Notebook
Sony VAIO PCV-RS720G (027242658103) PC Desktop Logo
121 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
