Question about Car Audio & Video
Stereo went dead while increasing volume to full blast which resulted to heating system not working as well. Tried bypassing behind the stereo and worked.Would like to the know cause and remedy pls.
How much power/wattage is your amp? What kind of car?
You may need to install a capacitor to harness some power to run the system, its ******* your cars electrical system.
Posted on Oct 21, 2008
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Mitsubishi WS-65511 volume control has gone crazy. All of a sudden volume went to full blast and now with manually pressing volume button it is either full volume or lowest volume. We have DISH and...
Mitsubishi WS-65511 volume control went crazy after a storm. Now we don't having any volume. None of the controls are working on the front of the panel with the exception of the device control.
Jun 02, 2010 | Mitsubishi WS-65511 65" Rear Projection...
No audio from mini input jack on Pioneer SupertunerIIID 50w x4
The mini jack was not designed to work in the manner in which you are trying to use it. The stereo output is always going to be at a higher output rate than the amplifier output. if you want to use an MP3 player with your stereo you will have to purchase a head unit with a built-in MP3 input or deal with the lower rate of volume.
Aug 13, 2009 | Pioneer DEH-P690UB CD Player
Erratic volume
Either the potentiometer which sits behind the user knob has got a broken track or it is full of debris
You can buy a tin of Servisol switch cleaner (or similar, make sure it has a lubricant in it and that propellant does not harm plastics) take off the knob and give it a good squirt where the spindle of the potentiometer enters the cabinet
Give the spindle a few full rotations and another dose of cleaner , then give it a try
It is best if you take a cover off and apply the cleaner direct to the potentiometer
Jul 01, 2009 | Creative Labs I-Trigue L3500 Computer...
Cd tray opens/closes by itself, intermittant full volume at start
I have a few ideas, but the model number is required for me to provide details. Can you please update this with the model number? Thanks, Dan
Jun 16, 2009 | Aiwa Audio Players & Recorders
Volume display seems backward
This is because the volume knob on ANY stereo is actually an attenuator.  Meaning, the stereo would play at full blast (way too loud!) if left to it's own limits of power, so your volume knob is actually "dialing down" the power, or when fully turned up, letting it all flow.
The reason that the numbers change like that is it's showing you how much attenuation is happening in decibels, or dB, so for insTance, when it's at "-30" that's a pretty decent volume, but at "-5" it's much louder and your neighbors might complain.  I think you'll notice that it can be cranked to something like "+5" which on my AVR 100 will blow the speakers.
In other words, this is normal, so relax and enjoy the music!
Dec 24, 2008 | Harman Kardon AVR 5 Receiver
Audio problem
Your problem is a common one with AUDI sound systems
Microcontroler in you device is failing.
When the stereo warms up, it stabilizes.
I know people who resolved thair situation by installing u 5W bulb inside the stereo to heat up the microcontroler. The solution lasts for a very short time because microcontroler burns up.
Second solution is to exchange the damaged microcontroler but you must find a person who knows what he is doing
And for the end, I never succeded to repair mine :)
Jul 02, 2008 | 2000 Audi A6
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sound is ridiculously low
if it is a stereo tv, there should be rca jacks on the back of the tv [red,white yellow] try connecting the rca outputs to a stereo system and see if the volume is any different.there might be a loose connection to the tv speakers inside.if you have a cable box hooked up to your tv, check the connections in back. you can also try bypassing the cable box by connecting the cable wire directly into the tv to see if it's the tv. if it is the cable box try unplugging it for a minute then hook it up again.i had the same problem with my cable box. hooking it up to a stereo system sounds like a pain, but at least you will have sound.
good luck
wg
Jan 30, 2008 | Toshiba 32AF44 32" TV
Car Audio & Video Logo
63 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
