Question about Kenmore Kitchen Ranges
Kenmore 790.91032404 I need a EOC
I have a Kenmore 790.91032404 serial number on the stone is VF61630969 The stone has a Electronic Oven Control that has the timer, clock and the over settings. I need one of those EOC'S I was also wondering what the part number is for the EOC. I would like to pay as cheap as I can if you know what I mean. Thanks
  • 5,911 Answers
Go to searspartsdirect.com and type in your model number as you have listed. Look under the "Backguard" heading for item number 20 (part #316455420). Keep in mind, the EOC does not come with the overlay. That's the plastic cover that goes on the EOC that has all your controls printed on it. If your current overlay is still in good condition, it can be reused by carefully peeling it off the old EOC and reapplying it to the new one. If, however, you wish to replace it, look for item number 20A (part #316220711). I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Oct 21, 2008
  • Paul Butala
    Paul Butala Nov 27, 2010
    is this part difficult to access and install? Any idea how many wires are involved ?
Kenmore gas range F11 error code
The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
Dec 13, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Electronic Oven Control for Kenmore model # 790-30172400
If the part numbers are the same then you can use that board. The revisions are to so that the control boards can be used on models that may have other features that yours may not.
Apr 23, 2012 | Kenmore Ovens
Kenmore oven giving F1 error code. Oven not working, but stove is working.
The "F1" fault code indicates one of the following possible failures:
  1. Shorted keypad which is part of the Electronic Oven Control (EOC)
  2. Failed Electronic Oven Control (EOC)
  3. Oven temperature sensor is bad (this is located inside the oven cavity at the upper left rear corner). The oven sensor should be disconnected and tested for resistance and compared with the "RTD" scale.
Jan 21, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Error code 065 jjj jjjj jjj 065 (frigidair Model feb398ceb)
2 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace F2 Oven too hot Check Bake function F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F4 Oven temperature sensor shorted Replace component F5, 6, 7 EOC (Electronic Oven Control) failure Replace component F8 Lock switches Check or Replace component Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control) F2 Oven too hot Likely a bad oven temperature sensor (should read 1100 ohms) Possible bad EOC (Electronic Oven Control) F3 Oven temperature sensor open Replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5 or F6 or F7 EOC (Electronic Oven Control) failure Replace EOC(Electronic Oven Control) Version 4 Failure
Code
Condition Check/Repair F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Nov 18, 2008 | Frigidaire Kitchen Ranges
I have a Kenmore Stove and the bottom (bake) element does not heat up. The top Element is fine. I have replaced the bottom element and checked the fuses and they seem fine. Could it be a control panel that...
You could very well have an Electronic Oven Control (EOC) board problem. There two separate circuits that control the oven BAKE and BROIL functions. If you have replaced the BAKE element, and have ensured it connected properly, the only other component that controls that function, is the EOC. If you post back with your complete model number, I can double check to make sure. The model number will be located on a nameplate somewhere around the oven door opening or lower drawer opening. The reason I need to confirm is because some ranges have a separate relay control board.
May 28, 2008 | Kenmore Kitchen Ranges
Oven beeping f1 and f3
Here are the error codes for your range:
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Nov 22, 2007 | Kitchen Ranges
Kitchen Ranges Logo
418 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
