posted by OzOnE on Jul 08, 2006
I have an MP1400 which has a blown power supply. The problem is, I can't find the code on the switch-mode controller chip as the top has exploded off!
The chip is the 8-pin SOP chip on the small daughterboard which stands off of the power supply module. This board has two optoisolaters on, and the chip in question is on the right.
If possible, I also need the codes for all the transistors and passive devices around that area. I also need the code for the 3-pin TO202 type device marked "Q2" on the main board of the same PSU module?
Or, does anyone know where I could buy a service manual for this projector?
Thanks in advance,
Ash Evans.
Suggest a new solution for this problem
Post a New problem for Compaq Microportable 1400 Multimedia
Email this problem
Email this problem
Can you Help with these Multimedia Projectors problems?
NEC LT170 projector won't turn...
Why won't my projector turn on... Answer This...
Shutting off Filter Cleaning...
I vacuumed all the filters on... Answer This...
Compaq Microportable 1400 Multimedia...
about ballast unit
about ballast unit
i have a projector compaq1400... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
