Question about Rio CE2100 MP3 Player
Frozenj i have a rio ce 2100 series and it is frozen on the saving settings screen is there a reset button on these mp3s i cant turn it on or off and its been frozen 4 quite some time the hsrdrive is not making any noises tho what can i do?
The reset button is the tiny hole on the top of the player to the left of the volume wheel. Use a paper clip to stick in the hole and push in the reset button for a second. Your screen should turn black and then turn off. Hopefully that will work!
Posted on Jul 09, 2006
SOURCE:
All i get is screen save display?
It seems you need to reset your phone.
If your HTC HD2 is frozen and a soft reset doesn't work, this guide shows how to restore your handset to its factory settings with a hard reset
There are two ways you can perform a hard reset on your HTC HD2. The first is best if your phone is still operational. If it has crashed and you can't get a response from it, you're better to try option two.
Performing a factory reset via the settings menu
  1. On the Home screen's Settings tab, select Menu - All Settings - System - Clear Storage
  2. Enter 1234 and tap Yes to confirm
Performing a factory reset using phone buttons
  1. If your phone has crashed and won't respond, you'll have to perform a battery pull to power the phone off. Simply take off the back cover and remove the battery. Otherwise, just turn your HTC HD2 off using the power button.
  2. With your phone powered off, press and hold the volume up and volume down buttons
  3. While holding the volume buttons, press the power button and then release it
  4. When you see a warning message on screen, release the volume up and volume down buttons
  5. Press the volume up button to perform the reset when prompted, or press any other button to cancel the reset
How to reboot the HTC HD2 with hard reset
Mar 31, 2014 | HTC HD2 T8585
HTC Wildfire touch screen frozen
You can try 2 things:
    1)Soft reset - clears memory and restarts program
    2)Hard reset - deletes all saved data and settings
    Soft reset
      -Locate reset button to right of USB port on bottom of phone
      -Press reset button with stylus
      -Wait
      Hard reset
        -Press and hold both talk and end buttons
        -Press reset button with stylus while holding talk and end buttons.
        -Release talk and end buttons and press enter
How to Troubleshoot Frozen HTC Touch
Aug 29, 2017 | iPhone Apps
The display is frozen and I can't get the watch to reset. I was beginning exercising and it is frozen on this screen.
If there are no reactions to any buttons, reset the
wrist unit by pressing all the buttons
simultaneously for two seconds. All other settings
except time and date will be saved.
manual is here
Dec 21, 2010 | Polar F4 Heart Rate Monitor Watch
My ce 2100 doesnt work anymore.. i plug it in and at shows a battery bar charging for a few minutes then the screen goes blank and i can turn it on or even charge it again can i change the battery?
yes. Once you plug it in it should automatically start charging. If the screen goes blank leave it for about 15 min. Unplug it and start it to see if it has charge. I hope this solution has been helpful.
Sep 24, 2010 | Rio CE2100 MP3 Player
Frozen screen
When the Sansa e260 is frozen, first try to reset the player.
How to reset the e200 series player:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
When resetting does not solve the problem, a reinstallation of the
firmware should be performed.
Need more help ? Just post a comment.
Dec 24, 2009 | SanDisk Sansa e260 MP3 Player
While registering my nuvi 205t on the website it recomended that i update my os i downloaded it only to find my 205 screen is frozen with this message "loader loading" its been that way for the last hour...
there is a reset button on the bottom, just push it in with ur fingernail. it resets ur settings but it saves ur favorites and preset locations. i had the same problem.
Mar 07, 2009 | Garmin nuvi 205 GPS Receiver
Cant enter pin or screen is frozen
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 11, 2008 | Garmin Nuvi 660 GPS Receiver
Volume Control on a Rio CE 2100 (2.5 GB)
This is a hardware issue - there is no repair svc for this one. sorry.
Oct 28, 2007 | Rio Carbon MP3 Player
Rio CE 2100 : insufficient space to index your content
I would recommend wiping your player:
Windows only.... Please post if you are not using windows...
Open My Computer with your Rio plugged in.
Right click on your Rio carbon and click on format.
Leave the default values - if it asks you something then use your initiative.
Then click on format.
Then when it has finished formatting go to your firmware (can be downloaded from: http://www.digitalnetworksna.com/support/rio/product.asp?prodID=235).
Follow the instructions and then it should load the firmware onto your player.
When it has done then your player should (in theory!) work properly.
Hope this helps
Mowcius
Aug 14, 2007 | Rio CE2100 MP3 Player
Rio Ce 2100 (2.5 gig)
hi http://server.iad.liveperson.net/hc/s-71042583/cmd/kbresource/kb-6922490712602368881/view_question!PAGETYPE?VisitorProfile=rio&action=view&documentid=42561&product=79 good luck
Apr 28, 2006 | Rio CE2100 MP3 Player
Open Questions:
Rio CE2100 MP3 Player Logo
99 people viewed this question
Top Rio Audio Players & Recorders Experts
Marvin
Marvin
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
