Question about Texas Instruments TI-89 Calculator
Ti-89 titanium when i graph a problem it sayswindow variables domain i just want to know how to fix the windows.
  • 49 Answers
2nd and f6 or something...
make sure minimum and maximum values aren't mixed up!
Posted on Nov 06, 2008
Error: Non-algebraic variable in expression
Non-algebraic variable in expression: error 790
If a is the name of a PIC, GDB, MAC, FIG, etc., a+1 is invalid. Use a different variable name in the expression or delete the variable.
Apr 22, 2015 | Texas Instruments TI-89 Graphing Calc...
Today i was trying to graph y=2x+23, but when ever i would press graph it would pop up window variables domain. What do i do to fix this?
Your ranges for your window settings are more, or less out of bounds with the equation y=2x+23, that you entered.
Press the [green diamond], and the [F2] keys to bring up the graphing coordinates. Enter the following values to fix the graphing coordinates. Starting at the top, xmin= -8, xmax= 8, xscl=1, ymin=0, ymax=40, yscl=1, xres=2. Now, press the [green diamond], and the [F3] keys, and the graph should display.
Dec 18, 2010 | Texas Instruments TI-89 Calculator
I'm trying to graph y=-2x^2 and it says "window variables domain"
Press diamond key, then window and then input the following values:
xmin = -10
xmax = 10
xscl = 1
ymin = -10
ymax = 10
yscl = 1
xres = 2
Then graphing function. See cap image
Aug 31, 2010 | Texas Instruments TI-89 Calculator
Windows variables domain. What does this means? I can't plot my graph.
It means that there's something wrong with your window variables.
Press Diamond F2 to bring up the Window editor and examine the values. Make sure that xmin<xmax, ymin<ymax, and the other values make sense for what you're trying to graph.
Feb 09, 2010 | Texas Instruments TI-89 Calculator
Everytime i try and draw a graph it comes up with window variables domain
The window variables are not correctly set. Xmin < or = Xmax; Ymin < or = Ymax. Press Apps key, select Window editor. In Window Editor set the values of Xmin, Xmax, Ymin, Y,ax or press F2:Zoom and press 6:ZoomStd.
Hope it helps.
Nov 22, 2009 | Texas Instruments TI-89 Calculator
How do you restore a TI-89 Titanium clac
Perhaps one of the following sources will be helpful:
To reset the TI-89 family, TI-92 family and Voyage 200 graphing calculators, press [2nd] [6] (reads MEM over the key). The [F1] menu appears and contains the following options:
  • All RAM - Clears all variables and programs from RAM only. This will not delete items from Archive or Apps.
  • Defaults - Does not clear any files from the calculator. Instead, this option resets the calculator settings to default, including the Mode, Graph Format, Table Setup, and other settings.
  • Vars - Clears all variables from Archive (Flash ROM). This option will NOT delete Apps or variables stored in RAM memory.
  • Apps - Clears all Apps from Archive. This will not delete any variables.
  • Both - Will clear all Apps and Variables from Archive. This will not delete any Variables from RAM.
  • All Memory - Clears everything from RAM and Archive, leaving only the Calculator OS and its components.
For example, I think you will want to follow the last step above... which would be to press [2nd] [6] [F1] [1] [1] [ENTER] [ENTER].
Also, if you are looking to clear all the RAM in another way I would take a look at the guidebook, which is downloadable from the following site in PDF format.
http://education.ti.com/downloads/guidebooks/graphing/89ti/TI89TitaniumGuidebook_Part2_EN.pdf
Take a look at page 951 and 952 for another way to clear the RAM
Jan 29, 2009 | Texas Instruments TI-89 Calculator
I am trying to graph r=sqroot(sin2theta) on my ti-89 titanium in polar mode and it is telling me when i try to graph that there is an undefined variable. what do i do?
Did you still need help with this? My suspicion is a missing multiplication sign. Sometimes you need to be very explicit in what you want the calculator to do. Have you tried sqroot(sin(2*theta)) explicitly putting the multiplication symbol in there? I think 2theta is interpreted as it's own variable name...
Jan 11, 2009 | Texas Instruments TI-89 Calculator
Error in graph
...with this process you will erase everything....
press "2nd" function and then "Mem"
then press "F1" and choose "3"
Press ok, and then wait, THAT'S IT!
May 20, 2008 | Texas Instruments TI-89 Calculator
I accidentally resetted my ti-89 titanium
Use the TIConnect software to connect the calculator to the computer.Then in the TIconnect main window you can drag and drop the applications you downloaded from education.ti.com. They will be transferred to the calculator.
I cannot understand why you cannot graph normally since the graphing is not an application, it is part of the OS.
While you are connected to the Internet and to the calculator, you may want to reinstall the OS directly from education.ti.com to your calculator
Hope it helps.
Feb 22, 2008 | Texas Instruments TI-89 Calculator
Graphing radical functions
I have a TI-89 Titanium and I have experienced the same problem. HERE IS HOW TO FIX IT:
Goto " MODE " and scroll down the options until you get to
" COMPLEX FORMAT " change that option to " RECTANGULAR " and press ENTER until you exit out of the " MODE " screen. (very important that you press ' enter ' until you exit because if you don't, it will not save your changes. )
Sep 19, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
244 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
