Question about Sta Rite STA-RITE SENSOR,FLUE TEMP - 42002-0024S
Testing how can I test a stack flue sensor on my sta-rite sr400na pool heater,I do have an ohm meter.
    Top Expert:
  • Sta Rite Master
  • 6,949 Answers
Jump for test if bad check gas pressure
Posted on Oct 11, 2017
5 Suggested Answers
SOURCE: Value Stack Flue Sensor
3.5 to 4K If you want to bypass the sensor just jump a 1 dollar resistor in between the two wires. If you want to put another sensor just use a standard gas heater flute sensor(2dollars) and put in line with the resistor
Posted on Nov 26, 2009
  • 990 Answers
SOURCE: Sta-rite pool heater shuts down as soon as the
Between the two water pipes on the left side of the manifold is a two inch plug. When you take this plug out the thermal regulator assembly will come with it.It consists of "O" rings, a spring and what looks like a thermostat in a car. This is the probal bad part although it could be the spring also. You can get these parts seperatly or in a kit. If this is an older heater the kit is the way to go so you get all the nessary "O" rings and you will be covered on everything you need.
Posted on Dec 08, 2009
  • 990 Answers
SOURCE: Water Temprature read 126 on heater and will not Fire
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Posted on Dec 21, 2009
  • 5 Answers
SOURCE: I have a e05 error
check the sensor that is on the exaust
Posted on Sep 09, 2010
Can I jump across stack flue sensor
Are your legs really muscular? If yes, then yes.
Oct 13, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Sta rite sr400na led11 red
check safety circuit and high limits also check gas pressure
Nov 11, 2013 | Sta Rite Sr400na Max E Therm Pool & Spa...
Can't get my sta rite spa heater to work
check gas pressure if too low overheating check safety circuit
Apr 03, 2013 | Sta Rite Pool & Spa
Shows r 5 code when power is turned on. sta-rite
The R5 is a sequence code in the boot up sequence where your error is occuring. There is nothing in the users manual for these pool heaters that explains this error. Your best bet, unfortunately, is going to be to call Sta Rite. Here is their customer service number: 1-800-831-7133
May 08, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Jun 14, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Feb 07, 2009 | Sta Rite STA-RITE SENSOR,FLUE TEMP -...
Sta Rite STA-RITE SENSOR,FLUE TEMP - 42002-0024S Logo
204 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
