Question about Toshiba TP43H95 43" Rear Projection Television
TOSHIBA 42PW23P rear projection television
When viewing picture its almost like looking through a magnifine glass almost tunnel vision. As you move to view different angles the big circle discribed moves with you? Like the plastic screen is warped but it isn't???
  • Toshiba Master
  • 3,459 Answers
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and fiTOSHIBA 42PW23P rear projection television - bb0cf99.pngre...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Mar 25, 2010
Need user manual for toshiba 42pw23p tv
This is an older Toshiba model. So the manual has to be accessed through the older models site: ftp://195.35.123.32/CCFTP/Manuals/ . The specific list of manuals for the CTV Projection TVs 42pw23p is here: ftp://195.35.123.32/CCFTP/Manuals/CTV%20Projection/40%20TO%2050%20INCH/42PW23P/ . The manual is available in several languages and as .zip or .pdfs. The direct link to the English version (pdf) of the manual is ftp://CCFTPcustomer:909ohedr@195.35.123.32/CCFTP/Manuals/CTV%20Projection/40%20TO%2050%20INCH/42PW23P/42PW23P%20English.pdf .
If you have trouble accessing the FTP sites, start here: http://portalcp.toshiba-tro.de/ and click on the Owner's Manual tab. Then click on the LCD TV link and choose the link for pre-2008 models (just above the model selection drop downs).
I hope this helps.
Nov 01, 2011 | Televison & Video
My Toshiba 53H71 rear projection TV's picture looks like double vision with a heavy tint outline how can I fix this???
Double vision/ picture problem occurs due to failure of convergence output ICs in rear projection tv and it is common problem of projection tvs.
Please replace convergence output ICs in tv to solve the issue, there is convergence repair kit available for $70 on This Site that has required parts/ ICs, instructions about how to replace ICs etc for a handy person.
Hope these info will help.
Thanks.
Jun 11, 2011 | Toshiba 53H71 53 in. Rear Projection...
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Toshiba 42PW23P colours are not merging together. You can see the colours separately. Think this may be a convergence problem or rainbow effect
Yes,ur convergence is dead.Must replaced these 2 convergence ICS and all it resistors to solved this problems.The shop well cost u $300 for parts and labors.
Feb 10, 2010 | Toshiba 42H81 42" Rear Projection...
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Ws-55809 mitsubishi projection tv tunnel vision
Good Day, kammey;
Sounds like your TV is having a Convergence Circuit failure. NOT an easy repair, so, call an Authorized Factory Service Center to come to your home and give an estimate B4 repair, $450.00-$650.00, depending on your location and the cost of gas. Good Luck, big IRISH.
Sep 01, 2008 | Mitsubishi WS-65809 65" Rear Projection...
3D like view on my screen
you ned to replace both convergence ICs they are STK392-570 you can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Aug 21, 2008 | Mitsubishi WS-55819 55" Rear Projection...
3d picture on my ge projection tv made in 1997
Replace the conversion amp ICs both of them cost about 15.00 each
Mar 10, 2008 | Toshiba 43H70 43" Rear Projection...
Toshiba 51H83 51 in. Rear Projection pisture issue
I have a wild guess. I have the same tv and channel 72 is the proper channel to watch tv on. I don't know why, but maybe try channel 72 instead of the usual channel 3. Good luck, maybe a quick fix, maybe not!
May 30, 2007 | Toshiba 51H83 51" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba TP43H95 43" Rear Projection Television Logo
173 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
