Question about HP Office Equipment & Supplies
When I tried to print several sheets of paper fed through at one time and got jammmed. I pulled them out and then the paper feeds real fast and nothing prints
  • 1 more comment
  • faypage Oct 21, 2008
    The printer is anHP Photosmart C4200 There is no jammed paper in the roller. The printer will copy but will not print from the computor and the paper feeds through real fast.
  • faypage Oct 22, 2008
    I tried your advice and it still did not work. My daughter in law came over and the problem was a document in the memory which I do not understand but it works now.
    The help you gave me did not fix the problem. As I said in my last comment my daughter in law came over and fixed the problem. It was something about a document I had still in the memory.
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Posted on Oct 22, 2008
    Brigadier General:
  • 6,966 Answers
Offhand, a couple of ideas, queries and suggestions:
  • Reboot your PC, pls verify that there are not pending print jobs in the HP PhotoSmart C4200;
  • Reset your HP PhotoSmart C4200
  1. Press the On button and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord back into the HP All-in-One.
  6. Plug the power cord into the wall outlet.
  7. Turn on the HP All-in-One by pressing the On button.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 21, 2008
    Guru:
  • 558 Answers
Since when this started.. (any specific you remember)
Reset the printer with power on button for 5 min. then check.
If it fail, then unplug the printer after power off PC and printer and then replug after 10 min., let it run and print.
Also clean the cartridge with a cotton or clean cloth -- the Nozzle and contact strip.. Also clean out the printer internal area..
If you can acess the roller then clean it out, let me know the further status.
  • 1 more comment
  • Puneet Jain
    Puneet Jain Oct 21, 2008
    Also get this tips from Official HP Website:
    HP Photosmart C4200
  • Puneet Jain
    Puneet Jain Oct 22, 2008
    Yes that you need to do if anytime same problem appear, go to Start --> Control Panel -> Look for printer--> select the printer and open --> window will appear which shows any printing process spooling.
    End them and restart printing if earlier take times. Let me know if problem still persists, and need any help from us.
  • Puneet Jain
    Thats what we have suggested you to reset which can erase all spooler memoriesof printer.
    Then why you not agree with the solution provided by us. It might be the case where you find it difficult to follow but the same thing have followed by your daughter.
    Genius:
  • 1,847 Answers
There might be still some paper jammed between the rollers, check
  • Legin Varghese
    Legin Varghese Oct 21, 2008
    open the cover and roll the roller by hand and check for any bits of paper between the roller.
    do let me know it is a ink jet or a laser one.?
  • Legin Varghese
    use the original cd that can with the printer to reinstall the printer driver.
    as you can scan the printer cartridge is working fine.
    Kevin
I'm getting ghost images on multi prints to the point it is unreadable, is this the drum or fuser?
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
Feb 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
Oct 24, 2009 | OKI C5500n Printer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Does not feed the paper correctly
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
Paper feed problem
The fault is the paper stop sensor is broken. Have the same problem myself. I don't think there is an easy solution to this as the sensor arm will have to be replaced and I think the m/c would have to be stripped down to do it. Nice to know if anybody has any ideas though.
Nov 09, 2007 | HP PSC 2355 All-In-One InkJet Printer
Paper will not feed
These are basically throw away printers. But you might try checking the paper path. There are small plastic "arms" that guide the paper as its picked up and goes throught he printer. Sometimes one of these may get stuck in a position that makes the printer think there is paper in the path somewhere.
Mar 19, 2007 | Apple Epson Stylus Color 777i InkJet...
37 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
