Question about Philips 51PP9910 51" Rear Projection HDTV
Double and curved image on blue warm-up screen
During warm-up the blue screen is curved with double images, on normal veiwing a blue ghosting is present. When the set is left on for a few minutes and then turned off and an one everything functions fine. The chassis is DPTV410. The error codes 61 and 16 where present in the CSM
  • Philips Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,PioneerDouble  and curved image on blue warm-up screen - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
My zenith sentry tv has a double image on the words that come on screen. The people are clear but all wording has double images
Hello
Double images are technically called Ghosts, occures due to the setting and direction on the antena. You have to reorient your antena, in such a way that Ghosts disappeares from your screen. The reson for this fault is not with the TV, as it gets a direct transmission signal, and a reflected signal of the same, reflected from near or far objects, like tall buldings, hills and so on. The signals, the orginal and the reflected, will be processed by the TVs internal ciiruit, and the first will appear as strong picture, followed by the second, a weak picture, will be seemed as an image of the first one, just on the right side [view point] of your TV.
You just adjust the position and height of your antena, looking the picture, where there is minimum Ghost level is. No other repair should be done to your TV, as it is perfect, and you just give it only direct signal path. OK.
Nov 22, 2010 | ZenithZ2541S 25" TV
My printer is printing double images and leaving dark ink marks on the paper
double printing or ghost images are usually cause by a fuser that is operating below normal temperature. the temperature is regulated by the thermistor replace it or replace the fuser
Nov 26, 2009 | HP LaserJet 1020 Printer
Double imaging (ghost effect) after several normal copies
you can tried to clean the fixing roller or exchange the drum
Oct 26, 2009 | Canon iR 2016i Black and White Copier
Blue ghost
I have blue ghosts/shadowing at the top of the screen.
Sep 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Double Image
Convergence repair needed.....order kit part # X480293....
has two IC's and some resistors...................T.
Mar 28, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Double image
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Mitsubishi VS-45609 TV
WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
DOUBLE IMAGES
How do we adjust convergence? I went to the service menu and all I see is alot of settings none of which help me out.
Can anyone explain this in further detail?
TIA
Aug 26, 2007 | Sony KP-53HS30 53" Rear Projection...
Philips 51PP9910 51" Rear Projection HDTV Logo
158 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
