Question about Panasonic Televison & Video
Panasonic CinemaVision PT51HX40B -- Shuts down within a few seconds of power up. If you repeatedly try to power on, smoke rises from a bank of 1/4 W resistors on the main board beneath the left most CRT. Is there a most likely cause for this particular model that would expedite the service process? It sounds like the high voltage is present momentarily (normal static sounds) and low voltage is evidenced by glowing of the CRT filaments just before shutdown.
  • 13 Answers
SOURCE: Convergence/power off
no sundog this model has the potenthal to be a nice tv when you saw the burn't resisters that was your clue to change the stk's now that you have fixed the res problem the bad stk is telling the set to shut down replace stk,s i ALWAYS change both (buy the way in the future those are hi watt res THEY SMOKED FOR A REASON maybe you thought they were installed in the 70"s ha ha. but they smoked because the stk's one or more are bad. good luck doc
Posted on Aug 18, 2006
Slinteriors
  • 8617 Answers
SOURCE: NO PICTURE AFTER FEW MINUTES/DARK PICTURE/ERRATIC/NO MENU VISSIBLE
Most projections have a removable speaker cover on the front under the screen. Then there is an access panel that you remove the CRT sockets are the circuit boards attached to the CRTs
Posted on Jan 22, 2008
Slinteriors
  • 8617 Answers
SOURCE: Panasonic PT-53WX53 cinemavision HDTV keeps powering off right away
5 blinks is telling you that IC4511 on the DG board is faulty. This is not serviceable you will need a new DG board the part number of that board is TNP2AA126
Posted on Mar 25, 2008
Slinteriors
  • 8617 Answers
SOURCE: no raster, no sound on 53UWX10B
double check the wire connections, as the filaments not being lit makes me thing a wire isnt connected properly, or one may have been loosend while doing the convergence repairs.
Posted on Jun 12, 2008
Slinteriors
  • 8617 Answers
SOURCE: Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Oct 14, 2008
My 51" Panasonic CinemaVision rear-projection HDTV
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Aug 12, 2013 | Televison & Video
I have a Panasonic cinemavision HD TV rear projection. It turns on and then shuts off as soon as the picture comes up. Can this be fixed?
Almost anything can be fixed.
When it shuts off does the power light on the front blink in a sequence like 3 or 5 blinks then pause and repeat?
Jan 21, 2012 | Panasonic Televison & Video
Bad color then no power on 51'' panasonic cinemavision
Check the power light for blink code--usually if this model shuts down the power light will blink in a sequence--3 blinks a pause and 3 blinks is short protection--usually means a convergence circuit problem.
Let me know what you find--I am here to help.
if this helped you rate this solution as I do this here for free.
SD TECH
Dec 17, 2009 | Panasonic PT-51HX41 51" Rear Projection...
TV powers up initially, but shuts down within seconds.
These TV's are somewhat sensitive to internal heat. It appears your sensor has triggered an overheat. This doesnt mean you still have the heat issue, it just saying it needs to be replaced or reset, either way it is not something you can do in your home. Taking it to your local authorized shop will ensure proper repairs, about $90 worth.
Jul 24, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
TV powers up for literally a second then shuts down (PT-47WX49)
check R517 on the power supply board if burnt replace with 5% 1/4 watt 10K carbon resistor.
Dec 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Mar 25, 2008 | Televison & Video
Panasonic Cinemavision 53" Projection 2002
TV's have a circuit in them that monitors the high-voltage and shuts the set down if it senses something amiss. On a projection type set, figure on just replacing the entire board that has the flyback transformer on it.
Dec 29, 2007 | Toshiba 32AF43 32" TV
Televison & Video Logo
85 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
