Question about Kenmore 22422 Top Load Washer
Kenmore 70 series
The machine starts fills with water then just stops? nothing else after water fills? Checked the line and all clear.Empty machine by hand start it again it fills then stops? HELP
I have a Kenmore 70 Series heavy duty plus # 82374810. The problem is the switch that turns on the machine. When I pull out the switch to operate the machine it fills OK but part way through the wash cycle it stops. I have to put a piece of wood under the switch to keep it running. Can you help me fix this, or find the part?
Maxine
Posted on Feb 08, 2009
  • 5,911 Answers
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your model number (located around the tub opening under the lid) and look under the "Top and Cabinet" heading. If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Posted on Oct 21, 2008
I have a Kenmore series 70 washing machine 110.26712693. I've been having problems for awhile with it - it will only fill enough water for a small load, it would start agitating at the beginning of the...
Remove the hoses which provide the washer with water. Check to make sure they are not clogged. At the back of the washer where the hoses connect there are screens. Check them to make sure they are clear also.
Jun 15, 2010 | Washing Machines
My kenmore 80 series washer will not stop filling up with water at the start of the cycle.
check the clear plastic line going to the pressure switch inside the console,blow into it to see if there is a hole in it or it could have slipped off the pressure switch, or you have a bad pressure switch,blow gently into the switch you should hear a click but it still could be bad,the pressure switch is what shuts the water down when it's filling and if there's a hole in the line or any air leaking out of the clear hose the water will not stop
Jan 30, 2010 | Kenmore Washing Machines
The wash machine will fill but wont stop filling
If it stops filling when you turn it off, the water level switch is malfunctioning. If the water runs in regardless, the water inlet valve needs replaced.
Dec 28, 2009 | Kenmore Washing Machines
My Kenmore Elite Oasis He Washer model #110.2706 will not fill with water. I have checked for blockage in the water lines and they are clean and clear. The washer is only two years old. It will hum like it...
Your fill valve needs replacing. Not too expensive to change. This is all based on the fact that you have checked both feeds to the washer hook up and that the shut off lever is fully open.
Jul 29, 2009 | Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Series 70 Washer Won't stop filling
yes and also make sure fill tube is not clogged or debreed
Jul 05, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
231 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
