Error code 0146 , can you help me ? - Computers & Internet
  • 749 Answers
ALWAYS CHECK THE WARRANTY BEFORE DOING IT YOURSELF
If this is a Dell computer , it indicates a hard drive failure. if so here is the solution:
Look at the bios and see if the hard drive is detected.
To get to the BIOS, when you turn on the system, you will be confronted with a black screen with the dell symbol in the middle, if you look at the top left of the screen, you should see something like
Press F2 for boot options
Press F12 for setup
Keep tapping the F2 or F12 key for boot options. this will take you into the BIOS.
Check also that it says enabled
Next see if you can boot the dell diagnostics partition. {F12}, then select diagnostics, once you have the diagnostics available run the memory tests and the hard drive test.
you should get a report when it finishes looking something like this:
DST Short Test: Failed
Error Code: 1000-0146
Msg: Unit 2 : DST LOC Contains previous error(s)
READ TEST:
0F00: 0244
MSG Block: 57301297
VERIFY TEST:
0F00:1A44
MSG Block: 57301297
if there are more than two errors ide suggest a new hard drive. BUT TO SAVE YOUR DATA BEFORE ------>Do you have anything important? if you do, you will need to do a repair install of XP and get your files before the hard drive fails completely. Use the service tag to obtain full specs of the computer at dells website. This hard drive has previous errors, and has generated new ones. It looks like it is getting ready to fail. You may be able to use a xp disk to perform an operating system repair, the dell operating system CD will do this also. Here is a link: http://www.michaelstevenstech.com/XPrepairinstall.htm If you follow the directions exactly, you will not lose any files. Please continue to post about this issue, and operate this computer as little as possible.
Posted on Oct 21, 2008
Let me throw a twist in the works.
I am getting the same error/failure. When I try to boot I get as far as the Windows Load Bar and it just sits there never moving forward.
Heres the twist. When I remove the hard drive and put it in another laptop, it boots up and runs like a champ. The drive is obviously not failing, if it were, it would fail on every laptop it was placed in. So if it works great in one and will not boot in another, whats the issue.
Any suggestions.
Posted on Nov 17, 2008
    Novelist:
  • 67 Answers
Hi starang91,
The technical meaning of the error code 1000-0146 or for short error code 0146 is = "DST Log contains previous error(s)." What this means that the Drive Self-Test (DST) already detected errors in the drive itself, usually bad sectors that corrupt data in the drive.
For this type of errors we susually recommend replacement of the hard disk drive since it means a impending failure of the hard drive eventually. So it''s important to backup your important files while you can still get into windows.
Hope this helps!
Peace! :)
2 Suggested Answers
tedmacaraeg
  • 181 Answers
SOURCE: Computer won't boot up. Error
Good day.
Error code 0146 basically refers to a hard drive. This means your computer is not detecting properly your hard drive or your hard drive itself is defective.
Let's first isolate the problem. Go to your BIOS setup (Pressing F2 upon power on) and check if your hard drive is properly setup in your BIOS. Make some necessary adjustments and save setting.
Turn-off your pc and try to check the data cable and the power cable is properly connected to your hard drive. You may also try re-seating the data and power cables - remove first and then connecting it again to the hard drive. Loose cables may cause problems. Power on the pc.
If you still receive the same error, then you need to replace the hard drive with another one.
Good luck.
Tedmac
Posted on Sep 29, 2010
Dell inspiron black screen error code 2000-0146
Error 0146 indicates a failed/failing hard drive or bad drive sector.
Basically, this means your hard drive will need to be replaced.
May 01, 2012 | Dell Inspiron Computers & Internet
Dear sir , i have a dell inspiron 1464 laptop.i have a problem during window installation.in a diagnostic test there are a error generate. the error code is, Error code 0146 Msg:Error...
Dear questioner after going through couple of posts on dell support forum I found that this problem occurs if your hard drive is not functioning well
If you laptop has warranty please visit the nearest dell store
Aug 06, 2011 | Computers & Internet
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Error code 0146 msg error code 2000-0146
You need a new, 2.5", 9.5 mm SATA notebook hard drive. Replace the failed drive. Then you will need to reload the operating system, applications, and restore your data from your backups.
for more help visit https://cbrtechsolutions.net
Jan 08, 2011 | Computers & Internet
Dell error code 0146 error code 2000-0146
I am afraid that this error normally points to a drive failure. You may need to get a new hard disk from Dell.
Dec 10, 2010 | Dell Inspiron 1525 Laptop
Does anyone know what code 0146 means?
This error code is related with the hard drive problem. There is a possibility of hard drive failure.
Mar 12, 2010 | Dell Inspiron 13 Notebook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
I get an error code 2000-0146 on my dell inspiron 1525 do you know what this is
The error code you got after running the Diagnostic test means the Hard drive fails and needs replacement. 2000-0142 and 2000-0146 is a hard drive problem. If you are still covered by the warranty. Just call Dell technical support, provide the error code and they will replace the Hard Drive.
Hope this helps
Jan 09, 2010 | Computers & Internet
2000-0146 is indicating a hard drive failure which is why it won't boot.
Jun 20, 2009 | Dell Inspiron 1501 Notebook
Deel inspiron 6000 error 1000-0146
Error code 1000-0146 is a hard disk drive failure, you'll need to replace the hard drive. If under warranty contact Dell for a replacememt. If not, you can buy replacements at newegg or other tech sites
Jan 26, 2009 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
32,048 people viewed this question
David Payne
David Payne
