Question about Toshiba 50HPX95 50 in. Plasma HDTV
Power ligh blinking no picture no sound
Is it the power supply? How much is it? hopefully its not too much :(
  • herry126 Oct 26, 2008
    Power light blinks. No picture. No sound.
  • tom0766 Dec 15, 2008
    Same problem as described above this tv set is almost 3 years old
  • 42 Answers
I had the same problem, it is usually the SEINE module. this unit is about 350 to 400 and they only come refurbished. You can bypass this module which is what I did and it worked sweet, and I have 2 hpx 95s they were both the same problem. This module is for HD off air only so if you are using that then you need a new one if you have cable or satellite save the money and remove the back of the TV and disconnect the module. Give the TV about 3-4 mins to reboot and HELLO TV.
Posted on Oct 27, 2008
60pk250
Bad inverter! There are usually boards on both sides of the screen.
Jan 12, 2014 | LG Televison & Video
42 inch philips lcd no picture no sound
Sometime a no picture, no sound still has the power light or some other led blinking. The blinks might be an error code that will isolate the problem.
In general on LCD TVs with no picture, no sound, no blink code, the main power supply has failed. The capacitors weaken and when bad enough, damage the power supply.
If there is a blink code, the most, if not all of the power supply is OK and the blink code could point to the problem.
Jan 19, 2011 | Philips 42PFL7422D 42 in. LCD TV
Monitor blinks on and off
The blinking power ligh is an indication of a failure in the power supply. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/capacitors/ that explains what goes out and what needs to be replaced. If you have additional questions about the repair you can post a few pictures in our forum section and our techs will point out the parts to replace. We also have a repair service if you don't want to do the repair yourself, click on the service request link on our web site at: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | ViewSonic VA1703wb Monitor
No picture and ligh just plinks
kathleen2002, If no picture, then do flashlight test! Six words and no punctuation will not garner much help on fixya here darlin. Tell us more. We need to know how old the unit is and or number of hours use. Did unit work perfectly the day before? Does this monitor get power from a "black lay on floor brick" or does it power up direct from wall outlet? When it worked last, did it have a bright, crisp image displayed on the LCD panel? If you are not a technician familiar with LC display technology you will NOT be able to repair it. As a consumer/user, your options are very limited. 1. NEC warranty if covered. 2. Cash+old monitor swapout with NEC for a refurbished 1550V w/new CCFT/inverter/SMPS. 3. Local Technician to refurbish your unit with new cold-cathode-fluorescent-tubes+Inverter supply repair if required and test unit's switch-mode-power-supply. 4. OR just trade up to a new and younger model. Bye for now. louie12fix on fixya or lmistyrel @aol.com
Sep 25, 2009 | NEC MultiSync LCD1550V 15" LCD Monitor
Same thing happened to me
Well, no sound no picture = power supply unit
Sound no picture= flyback
picture no sound =tuner/audio logic
You get my drift?
You power supply is bad you replace it you got another new TV, with this digital conversion hitting I would rather advise you to get a nice flat panel and donate that one to Goodwill
Jun 13, 2009 | RCA F32650 32" TV
Tv does not come on
CHECK THE MAIN POWER SUPPLY , either for fuses or replace power supply board. hope it helps , AJ
May 07, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Sony 34 No picture or sound the standby lite just keeps blinking.
Does the ligh blink a certain number of times and the stop briefly and repeat the same pattern? If so you have a problem that is beyond your ability to service it and must be serviced by a certified sony tech.
Feb 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture tp50g50
Sounds as thought you have a dead B+ from the power supply board. Replacement of the board should be a certain fix. The power supply could be fixed with the help of a good service technician. I hope this has helped.
Ed
NC Electronic
Mills, Wyoming
Dec 25, 2007 | Toshiba TP50G50 50" Rear Projection...
Toshiba 50HPX95 50 in. Plasma HDTV Logo
393 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
