Question about Toshiba 36A40 36" TV
Channels keep changing
My TV was working fine but now when I hit the channel up or down it keeps moving and if I hit the volume it keeps going up or down. I changed batteries and even tried a new remote but it is still happening. If you have the answer to this problem please email mim3467@aol.com. Thank you.
  • Mary Beth Jul 10, 2006
    So far the unplugging for a time worked! Thank you very much!!
  • 26 Answers
Ok, let's try the simplest things first.... unplug the tv from the wall, and remove the batteries from the remote. wait about 5 or 10 minutes. reinstall the batteries and plug the tv back in. try it again. actually since you said you tried another remote, you can skip removing the batteries from the remote. if it still does it, try unplugging the tv overnight. if it still doesn't work right then, you have a processor problem, and need to have it looked at by a service tech.
Posted on Jul 08, 2006
    President:
  • 3,130 Answers
WRONG!!!! do not pass go , do not collect 200 smackeroons!!!! lolol Your problem im pretty sure is a stuck channel up button or the switch inside is broken or stuck.
    Problem Solver:
  • 6 Answers
If your tv is already old change the two channel control switch then it works fine
Posted on Mar 16, 2007
How do you change the tact switches on the front panel of an RCA TV model F32649?
Thanks for your help.
Cindy
Guyton, Georgia
Posted on Sep 13, 2010
4 Suggested Answers
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
bernardlunda
  • 318 Answers
SOURCE: toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Posted on Apr 08, 2009
SOURCE: Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Posted on Oct 20, 2010
I have a Samsung 32 inch LCD tv that constantly changes channel on its own. I switched it on this morning and it was working fine then the volume went to max and I couldn't turn it down. I then switched it...
You say the remote doesn't work but it may well be the problem. Take the batteries out of the controller then try using the tv using the controls on the TV.
Dec 02, 2010 | Televison & Video
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Power button changes channels and volume does not work
bad solder connections. front control panel.
Nov 23, 2008 | Philips 27PT543S 27" TV
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
TV turns itself on, keeps changing it's own channel
the problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
Jul 06, 2008 | Televison & Video
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Ghosts?
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
Keeps changing channels/volume by itself
One or more of the front switches are likely leaky.  They are less than $3 apiece and I just change them all to save future problems.  You might be able to push all of the buttons on the front of the set a few times such as volume up and down and channel up and down and temporarly cure the problem but the switches will likely need to be changed.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 16, 2007 | RCA F32650 32" TV
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Dec 18, 2006 | Sony KV-27V42 27" TV
Toshiba 36A40 36" TV Logo
274 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
