Question about Emerson (CKS2235B) Clock Radio
New Daylight Savings Time Change Schedule
I have an older Emerson Smartset CKS2235B that still adjusts for daylight savings time on the old schedule.  Does anyone know how to set this clock to the new DST schedule?  Thanks, Steve  droppler525@yahoo.com
5 Suggested Answers
SOURCE: Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Posted on Jun 16, 2008
I have same problem with Zewnith Z230 clock radio. Is tgere a sikytuib>
Posted on Oct 27, 2008
  • 814 Answers
SOURCE: New daylight savings schedule
(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.
Posted on Jun 12, 2009
  • 5228 Answers
SOURCE: Directions for Resetting the Daylight
Unfortunately, you can't reset the firmware of the clock for those built before Jan 2006; you can work-around the issue. You will need to change time zones for the few weeks between the current daylight savings start and end dates and the ones that were built into the clock. For details see: http://www.emersonradio.com/dst.htm ; click on the link for Group 1.
If the unit was built before Jan 2006 (the serial number will start with a value less than 6), switch the time zone to the next one further east on the second Sunday of March, then set it back to your correct time zone on the first Sunday of April. Repeat this on the last Sunday of October and the first Sunday of November. (If you are in the Eastern time zone (zone 2), set the switch to zone 1.)
If the unit was built between Jan 2006 and July 2006 (serial numbers that start 601 to 606), then you can change the start and end dates for DST. See: http://www.emersonradio.com/dst.htm then choose the Group 2 link. Press and hold the Alarm 1 button then press the Month/Date or Calendar button. After three seconds the unit will display the start date for daylight savings. Press and hold the Alarm 1 and Month/Date or Calendar buttons. When the display is flashng (within 5 seconds from the press and hold step), press the Down or Set button (depending on the SmartSet mode) three times until the display reads 3 and F2 (alternating with the date of that Sunday).
For the end date, press and hold Alarm 2 then press the Month/Date or Calendar button. Then press and hold Alarm 1 and the Month/Date or Calendar button. Again within 5 seconds, press the Up button or Set until the display shows 11 and F.
If the display stops flashing, repeat and set the new dates faster.
You'll have to repeat this is the battery is removed or replaced.
I hope this helps.
Posted on Mar 15, 2011
How do you correct the daylight savings time problem
If your clock changed to DST late then it's hardwired for the old changeover schedule - and there's no way to reprogram it. All you can do is reset the time manually or change your time zone setting to "fool" the clock into displaying the correct time. Either way, you're going to need to reset the clock as many as four times a year to keep the correct time. The ultimate solution is to replace the clock with one that's set up for the new DST schedule.
May 08, 2010 | Emerson Smartset Clock Radio
Daylight savings time changes at wrong date on my brookstone 'smartset' alarm clock. (It changes at the old date, of course - so it is wrong 4 times a year...)
The DST schedule is hardwired into the older clocks and cannot be modified to run on the new schedule. If the clock has a DST switch, you can can turn it OFF and reset the clock only twice a year. On my old "ATOMIC" clock, I've set the DST function OFF, and I use the time zone switch for my adjustments. Sorry, but your only other choice is a new clock.
Bill B
Apr 05, 2010 | Brookstone SmartSet CD Alarm Clock Radio
How do I get my smart alarm clock to reset itself automatically since the goverment changed the daylight savings time? Or, if I buy a new one will it have the new time changes?
The Daylight Saving Time settings are not user controlled, so you cannot convert the changeovers to the new schedule - you can only change the time manually. Any new clock or clock radio with automatic settings will work on the new schedule.
Bill B
Apr 04, 2010 | Emerson Smartset Clock Radio
MY CKS1850 SMART CLOCK. IT IS A FEW YEARS OLD. IT
The daylight saving time change is calendar based, and unfortunately there is no way to reprogram it to the new schedule. You'll have to make the time changes manually.
Jan 11, 2010 | Emerson SmartSet CKS1850 Clock Radio
My clock went back one hour on Sunday 10/25, need to get it to move ahead one hour.
The clock program for Daylight savings Time is programmed for the old "third Sunday in October" changeover. The new changeover is the first Sunday in November. The program probably cannot be updated. If there is no button or setting to disable automatic change to Daylight Savings Time you can set the time manually and then change it manually to Daylight Savings on November 1 for the time to be correct.
Oct 26, 2009 | Emerson Smartset Clock Radio
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
There was a sheet of paper that came with my clock explaining how to adjust the daylight savings time settings, but I lost it.  Anyone have theirs?  All i know is it requires that you press an awkward combination of buttons simultaneously, but that's it.
Nov 06, 2007 | Zenith Z230S Clock Radio
Emerson Smartset Radio Model CKS2288
The Daylight Saving dates appear to be hard-coded per the manual:
Start of Daylight Saving Time:
At 1:59.59 AM on the first Sunday in April, the clock will automatically advance to 3:00 AM.
End of Daylight Saving Time:
At 2:59.59 AM on the last Sunday in October, the clock will automatically reset to 2:00 AM.
So the easiest thing to do is to change your time zone up or down one for the period between the new DST date and the old -- or you can buy a new SmartSet for about $15. The newer ones do not have the same problem.
Oct 29, 2007 | Emerson Smartset Clock Radio
Daylight saving time issues
I picked this up from the Emerson Website Read below before going to the link. Try thi link: and poke around the website http://www.fox-international.com/emerson/ Important Notice About Daylight Saving Time (DST) and Emerson SmartSet® Clocks and Clock Radios Congress recently passed a new Energy Bill which includes a provision to extend Daylight Savings Time. At the beginning of 2007, Daylight Savings time will begin on the second Sunday in March and end on the first Sunday in November. Because of this change your SmartSet® Clock or Clock Radio will need to be updated. In order to set your unit we will need the following information from you: 1. Model Number You can find your model number on the back or bottom of your unit. (Click here for an example) 2. Serial Number You can find your serial number on the back or bottom of your unit. (Click here for an example) Based on this information we can identify which setting is necessary to adjust your unit for compliance with day light savings. There are three possible groups your SmartSet® Clock or Clock Radio could fall into: Group One changes the time zone to a previous time zone. Group Two adjusts for the spring and fall settings. Group Three is already set for 2007 daylight savings compliance. Group identification begins with your serial number. The first three to four digits of the serial number represent the year and month of manufacture. (If your serial number begins with 0607, that would indicate July 2006, 506 would indicate June 2005.) Models manufactured before January 2006 (serial number 506, 512, etc.) will follow Group One settings. Models manufactured between January 2006 and July 2006 (serial number 0601, 0603, etc.) will follow Group Two settings. Models manufactured after July 2006 (serial numbers beginning with 0608) are Group Three and do not require any changes. If you believe you have a Group One model, please click here. If you believe you have a Group Two model, please click here. If you cannot determine which Group your model may be in, please call us at 1-800-526-7521.
Mar 11, 2007 | Emerson SmartSet CKS1850 Clock Radio
Emerson (CKS2235B) Clock Radio Logo
179 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
