Question about Yamata FY14U4AD
Bobbin doesn't fill in bobbin winder
I just got a yamata 8500 industrial machine and I'm trying to get the bobbin winder to work, with no luck, does any one know why the bobbin is not getting the thread? when I put the bobbin in the winder it seems to me that it is a little lose is it suppossed to be snug? please help. Thanks
    Problem Solver:
  • 14 Answers
The bobbin winder question is a frequent one and it is very easy to solve. If you look at the shaft where the bobbin sits on the bobbin winder, you will notice that it has a slot in the middle of the shaft, an opening if you will. This is where you use a flat screw driver and open that space more to give more friction to the bobbin so it is not loose on the shaft. That slot was made for that. There are different bobbins on the market so thats why the slot is there. If it is too tight, grab a pair of pliers and close the gap. The metal of the bobbin winder on that shaft is malleable exactly for this reason. No need to put plastic bag material or anything like that. Use it as it was intended for.
Posted on Jul 08, 2008
Actually the thread needs to be not only started around the bobbin but also go through the slot at the end of the bobbin shaft to accomplish the same thing as the plastic bag
Posted on Feb 03, 2008
Yes i have found the solution if this is help to anyone, the bobbin needs to be tighter around the winder so i put a small plastic bag material on the winder where the bobbin goes and put the empty bobbin on top, wound the thread round and it started filling it up. So remember the bobbin must be firmly stuck on winder. Hope that resolves anyones problem, it did mine.
Posted on Sep 16, 2007
The belt isn't touching wheel to wind up the bobbin what can i do to fix it
Posted on Apr 03, 2009
I have my machine threaded for filling bobbin. I hit the pedal but it doesn’t fill??
Are you actually activating the bobbin winder by pushing the activator over?
Jul 04, 2018 | Sewing Machines
When I try to fill my bobbin the thread gets all balled up on top of the bobbin instead of filling it. What should I do?
Consult your owner's manual. Chances are you may be threading the thread incorrectly. Make sure it is going through the bobbin winder tension guide before going to the bobbin winder mechanism.
If it continues, the bobbin winder may need a height adjustment. I had that issue with a machine that the case surrounding the bobbin mechanism was slightly misaligned. Once it was fixed, the bobbin winder worked perfectly.
Dec 01, 2015 | Sewing Machines
When i turn the balance wheel or use the foot controller, the needle doesn't raise or lower. I put the bobbin winding assemby in the right position. The machine is on.
Is this a machine where you have to tightnen the clutch in the middle of the handwheel? Or is this one where the clutch disengages when you switch the bobbin winder on?
If it's of the second type, try turning the bobbin winder on again, and then off, crisply. Otherwise my best guess, barring other information, is that the lubricants have gone gummy or evaporated. Do you hear a motor hum?
Jan 03, 2014 | Yamata FY700 Mechanical Sewing Machine
Elna lotus tsp
I would really suggest having the machines bobbin winder checked at a sewing machine repair shop..
Jul 10, 2013 | Sewing Machines
Can't find needle size for my machine
Try an industrial supplier... especially one that sells Yamata.
Nov 11, 2012 | Sewing Machines
My bobbin won't catch on the bobbin winder, the metal post spins but the plastic singer style bobbin won't spin with it. What's wrong?
The bobbin may be stripped, or the bobbin winder might be stripped; try it with a different bobbin, to rule out the bobbin being the issue; if that doesn't work, look closely at the bobbin winder to see if it has been damaged. You may be able to adjust it's shape with a pliers
Apr 02, 2012 | Singer 3116 Simple
I just bought a used juki DDL 8500 industrial sewing machine. It didn't come with manual. I also can't find a bobbin casing. I feel very foolish. There appears to have a bobbin winder on the side....
I just bought the same machine and mine came with a photocopied manual. There is indeed a bobbin winder on the side, there's a flat section on the side of the bobbin winder closest to you, if you push that forward it connects a wheel attached to a bobbin spoke, to the belt that runs between the machine and the motor. To wind the bobbin, put the bobbin on sideways onto the axis of the wheel that is on the inside of the machine, and push the bobbin winder forward.
If you're looking for where the bobbin case is located on the machine, if you look underneath the machine on the left hand side, there should be a metal belly, on the left side of the belly is an opening, and in there sits the bobbin casing.
I think you were asking for either one of these answers, I'm on here troubleshooting for my Juki DDL-8500, good luck with yours, hopefully I can find what I need to know too!
Feb 07, 2010 | Juki DDL-8300
Bobbin Winder not working
sounds like the bobbin is not all the way down on the peg.
May 15, 2009 | Kenmore 11101 Mechanical Sewing Machine
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Bobbin case
Make sure there is no fabric or thread on the bobbin case shaft. Needle has to be in up position.
Feb 19, 2008 | Yamata FY811 Mechanical Sewing Machine
Yamata FY14U4AD Logo
797 people viewed this question
Top Yamata Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
momlet
momlet
Level 1 Expert
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
