Prompt boxes filling with dashes
My pc has started inserting dashes into whatever prompt (web address, excel cell, google search entry box) the cursor was on when it went into idle mode. This happens whenever the PC has been inactive and it goes into power save mode, and when it first starts up. At the password prompt to login it starts filling with dashes before I can start typing.
A related problem is that sometimes when I access my favorites from my browser and there is a folder of favorites, I click on that folder and the browswer opens a browser tab for each entry in that folder!
WHat's going on?
  • powells-jmp Oct 21, 2008
    I examined the keyboard and found that the '-' key on the numeric keypad was pushed in. Easy to find and fix. Thank you Siawolf for this suggestion.
    Regards
    John
  • 749 Answers
Keyboard has a ticky key , shake it upside down or try a new one .
Posted on Oct 21, 2008
Unable to find Ip address of printer
Your router will show a list of the DHCP leases. This is a list of the IP addresses.
OR:
Windows 7 & 8
  1. Click the Start button
  2. Type
    cmd
  3. At the top of the Start menu, cmd.exe should appear. Click on cmd.exe.
  4. A black command box will appear with a blinking cursor.
  5. At the blinking cursor, type
    ipconfig /all
    Press Enter.
  6. Below the heading "Ethernet adapter Local Area Connection:" look for the
    - IP Address entry
    - Physical Address entry
May 10, 2016 | Office Equipment & Supplies
Tip
Windows XP HELP Windows key + R = Run menu cmd = Command Prompt iexplore...
Windows XP HELP
  • Windows key + R = Run menu
  • cmd = Command Prompt
    iexplore + "web address" = Internet Explorer
    compmgmt.msc = Computer Management
  • Windows key + E = Explorer
  • ALT + Tab = Switch between windows
    ALT, Space, X = Maximize window
    CTRL + Shift + Esc = Task Manager
    Windows key + Break = System properties
    Windows key + F = Search
    Windows key + D = Hide/Display all windows
    CTRL + C = copy
    CTRL + X = cut
    CTRL + V = paste
  • Keyboard Shortcuts
  • [Alt] and [Esc] Switch between running applications
    [Alt] and letter Select menu item by underlined letter
    [Ctrl] and [Esc] Open Program Menu
    [Ctrl] and [F4] Close active document or group windows (does not work with some applications)
    [Alt] and [F4] Quit active application or close current window
    Ctrl] Lft., Rt. arrow Move cursor forward or back one word
    Ctrl] Up, Down arrow Move cursor forward or back one paragraph
    [F1] Open Help for active application
    Windows+M Minimize all open windows
    Shift+Windows+M Undo minimize all open windows
    Windows+F1 Open Windows Help
    Windows+Tab Cycle through the Taskbar buttons
    Windows+Break Open the System Properties dialog box
    explorer shortcuts
    END....... Display the bottom of the active window.
    HOME....... Display the top of the active window.
  • Type the following commands in your Run Box (Windows Key + R) or Start Run
  • devmgmt.msc = Device Manager
    msinfo32 = System Information
    cleanmgr = Disk Cleanup
    ntbackup = Backup or Restore Wizard (Windows Backup Utility)
    excel = Microsoft Excel (If Installed)
    msaccess = Microsoft Access (If Installed)
    powerpnt = Microsoft PowerPoint (If Installed)
    winword = Microsoft Word (If Installed)
    frontpg = Microsoft FrontPage (If Installed)
    notepad = Notepad
    wordpad = WordPad
    calc = Calculator
    mspaint = Microsoft Paint
    wmplayer = Windows Media Player
    control = Opens the Control Panel
  • Internetbrowser
  • type in u're adress "google", then press [Right CTRL] and [Enter]
    add www. and .com to word and go to it
  • For Windows XP:
  • Copy. CTRL+C
    Cut. CTRL+X
    Paste. CTRL+V
    Undo. CTRL+Z
    Delete. DELETE
    Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE
    Copy selected item. CTRL while dragging an item
    Rename selected item. F2
    Move the insertion point to the beginning of the previous paragraph. CTRL+UP
    Select all. CTRL+A
    Search for a file or folder. F3
    View properties for the selected item. ALT+ENTER
    Close the active item, or quit the active program. ALT+F4
    Opens the shortcut menu for the active window. ALT+SPACEBAR
    Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4
    Refresh the active window. F5
    Cancel the current task. ESC
    on Oct 12, 2010 | Computers & Internet
    How do i find my mac address on my computer
    If you are running any version of Windows, click on Start and in the search box type cmd. Then click on the command prompt entry. This should bring up a black box with white letters on it. Type in ipconfig, then press the enter key. This will display the information for your network adapter. The mac address is listed.
    Jul 18, 2014 | Acer Aspire Computers & Internet
    Excel to word tables linking
    Excel and Word are two parts of the Microsoft Office Suite that have become standards tools for spreadsheets and word processing.
    Among their features are the ability to easily exchange information.
    For example, you can easily copy a cell or part of a spreadsheet from an Excel and paste it into a Word document, which preserves all the formatting.
    This method requires opening up both programs at the same time.
    To avoid this, you can insert an Excel file from within Word itself.
    Choose the "Insert" tab inside Microsoft Word to display the Object dialog box.
    Click the "Create from File" tab and Browse to display the Browse dialog box.
    Navigate to the Excel file that you need and double-click to load its name into the File Name box of the Object dialog box.
    Click a checkmark into the "Link to File" box if you want the table that you insert to be automatically updated anytime the original file is changed.
    Otherwise, leave it blank if you don't want the inserted information to be affected by the original file.
    Click "OK" to insert the Excel file as a frame into the document.
    Note how only filled cells from the first table (worksheet) of the file are inserted.
    Blank cells are not inserted. You can resize the frame by clicking it and dragging the handles that appear.
    You can also click it and drag it to a different line within the document.
    http://office.microsoft.com/en-us/word-help/link-or-embed-an-excel-worksheet-HA010120810.aspx - BM4
    Aug 07, 2013 | Microsoft OFFICE 2013 HOME AND BUSINESS 1...
    NEED TO SET UP A GOOGLE ACCOUNT
    Google started as a search engine and since has added many applications. All these applications are available to you once you set up your Google account. Setting up an account is easy.
    Point your web browser to the main Google web page. The main Google page is the starting point for searches and other applications and features. You can sign up for an account, manage your Gmail or start a Google group from here. Find "Sign In" at the top right-hand corner. This is a link and will lead you to where you can sign into an account or create one. Fill out the required form. Google ask you for a current email address, password, word verification and location. They also have the terms of service. You must read and agree to these before going on. Verify your email address. Once you have submitted the completed form, Google will generate an email to your email address. It will have a web address that you must visit to verify that you received the email. Log in to your new Google Account. Use the email address and password that you selected during sign-up. You now have access to all the Google features. Explore your new Google account features, including email, groups and the personalized homepages. TIP : If ever you need to get google homepage back from other search providers try to take over your search engine Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if dont need any of them you can disable or remove them
    Hope this helps.
    b>
    Jan 06, 2013 | HP Computers & Internet
    What is formula to use 5 point drop down list to prompt entry of cell value into specific location
    You can use cell validation.
    Select the cells you want to have the dropdown list.
    Press the following keys "alt" "d" "l" and you get a message box.
    select List from the drop down.
    Now you can type in your list in the blank box separated by commas
    Nov 29, 2009 | Microsoft Excel for PC
    Need the ability to "tab" from field to field on right of kybd
    When you press ENTER to finish working in a cell, Microsoft Excel moves the cursor one cell down by default. However, you can select the direction in which you want the cursor to move.
    1. On the Tools menu, click Options.
    2. On the Edit tab, do one of the following:
      • To change the direction in which the cursor moves, select the Move selection after Enter check box, and then select a direction in the Direction box.
      • To keep the cursor in the current cell, clear the Move selection after Enter check box.
    Note When a range or set of ranges is selected, pressing ENTER moves the cursor within the range or set or ranges only.
    Jan 22, 2009 | Logitech Marble Mouse Trackball
    Computers & Internet Logo
    David Payne
    David Payne
