Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Refrigeraotr is out but freezer still works
Overloaded freezer may have caused fan to go out? Is this possible? Cleaned dust from compressor and shut off to let it cool down but it is still not working The model # GLRT13TES0 Serial # is LA51601700 The manufacturer date is 2004 - 2005
  • torpedoman Oct 24, 2008
    I have this problem now. I noticed the freezer setting was maxed out. Can this stop flow to the fridge below?
    Jeff
    President:
  • Frigidaire Master
  • 2,651 Answers
Doesnt make adiff how you loaded freezer, shouldnt affect fan operation anyway. if you have a meter you can check for proper voltage(110v) to fan wires and if you have power youll need to replace fan, easy enough to do just a few screws and about $50.. part number 5304445861.
Posted on Oct 21, 2008
The freezer stopped working (the fridge is working but not as cold as it should be), I cleaned all the vents and the freezer worked again fro a short time then I heard a noise like possibly the fan...
It does sound like a bad fan motor. With the compressor getting hot you may need to change the start relay, overload and run capacitor if it continues to run like this with a defective fan motor. What is the correct model number? Sea Breeze
The condenser fan motor for a model MZD2766GES is part number=> 61005323 Condenser Fan Motor or here=> 61005323 Condenser Fan Motor
Oct 18, 2013 | Maytag MZD2766GES Side by Side...
Display not working
Hello Lan Sutton - Since the unit is now not cooling, when was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator or control board may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
Nov 25, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
GE Profile Side-by-Side running warm
If it's cutting off at too high a temperature it is a good possibility the probe is faulty. However if the compressor is not cutting off at all, suspect short of gas.
Apr 24, 2012 | Refrigerators
Model ffu213caw1: my freezer stopped cooling recently.there is power to the uniti hear a small click down near the compressor like it is trying to start and then it stops.compressor is warm to the touch...
Compressor is bad the clicking noise is the Start Relay/Overload is kicking on and off. compressor is warm because it's trying to start but can't Frigidaire is known for bad compressors. I don't think the Start Relay/Overload is bad because the compressor gets warm.
May 20, 2010 | Frigidaire 21 cu. ft. / 595 liter Upright...
Things in freezer melt and re-freeze
Your condenser fan motor at the compressor is either filthy or needing to be replaced. Air flow is pulled over compressor to keep it at a good operating temp. If the fan cannot pull air across compressor it will over heat and shut down on overload. Imagine working in yard on hot summer day and wearing a dust mask over your mouth and nose. Your body shuts down more needing more rest. Same thing with refrigerators, they have to be able to breathe properly also.
Jan 27, 2010 | GE Freezers
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
Freezer fan runs for hours
When compressor cycles off, your freezer fan should shut off as well !
Freezer fan should not be spinning while compressor off.
You might need a control board replacement, that controls fan.
If you are talking about compressor run time, that is a bit excessive, usual causes are dirty condensers but you say they are clean - are your condensers at the bottom of the unit ? If so make sure the condenser fan next to the compressor is running too, blowing air ont he condenser.
Sep 26, 2009 | GE Refrigerators
Refrigerator is out but freezer still works
Hello dan_2137
Welcome,
You said, overloaded freezer may have caused fan to go out? Is this possible? Cleaned dust from compressor and shut off to let it cool down but it is still not working
Yes It's possible. If the freezer is so packed full where the packages cover the air vents in the rear of the freezer.
The freezer and the fridge share the cold air and this is the first think we look for if the fridge is warm and the freezer cold, And the fan works nonstop rather than cycling off and on!
What is the model number and year of your fridge!
Waiting your response.
Huuum
Please remember to leave a rating!
Oct 20, 2008 | Frigidaire FRT21H8 Top Freezer...
GE refer Model #TCS18PADBLBS Bottom freezer
the compressor should reset it self and the fan you just have to dig behind the rear panel for it chances are the blade is rubbing the shroud
Dec 03, 2007 | Refrigerators
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
93 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
