Question about BenQ PB6110 Multimedia Projector
BenQ PB6110 Power turn off
Hi there !!! Just try to turn on my projector, but he just started  and immediately turn off the power. What can be the problem?
  • jhubert Apr 03, 2009
    Haven't used the projector for some weeks and now it won't turn on. Appears to be in normal stand-by mode. After pressing the power button starts to boot up and then shuts down after 5 sec. In the past I sometimes had to press power button twice before boot-up would continue.
Marrie
  • 563 Answers
SOURCE: Benq PE8700 - Won't Power Up
Hi there
Trust me that the Mainboard needs replacement.
I am very familiar with the PE8700's as I am a ASP Technician for BenQ.
Visit www.BenQ.com and look for the link to your country - you should be able to allocate a Approved Service Provider.
Must warn you that the Mainboards on these models are quite expensive.
Posted on Apr 01, 2008
SOURCE: PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Posted on Nov 18, 2008
SOURCE: BENQ PROJECTOR
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
Posted on Apr 10, 2009
vortash
  • 431 Answers
SOURCE: BENQ PB6110 - will not power on
Hi I am Vortash check the lamp housing is secure as most units have a safety switch on them to disconect the projector from the supply while a bulb is inserted .. I fthis is secure and the fuse is not blown I suspect the lamp or the ballast .. look for dry joints on the board for the lamp or unseated plugs other than that unless your friend can trace the psu switch mode power supply back to it's individual outputs and check that it is working correctly your going to have to take it to an engineer sorry .. hope this helps Regards Vortash
Posted on May 17, 2009
  • 3 Answers
SOURCE: BenQ PB8220 DLP projector - lamp button continues to flash after bulb replacement
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the lamp´s temperature circuit. A technician disassambled my BENQ PB8253 unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
Posted on Sep 14, 2009
On screen resolution issues
Bought a new XGA projector.../
It appears from researching that the native res for the Benq is too low 800x600 so I will never get a good picture even though most of the images I install are at least 10meg originals. Also the new projector will work in a bright room the Benq will not.
May 07, 2009 | BenQ PB6110 Multimedia Projector
Apr 15, 2009 | BenQ PB6100 Multimedia Projector
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
Benq 6110 - mounting projector onto ceiling
You need to navigate to the 'advance' menu and under the 'mirror' setting select 'ceiling front' or 'ceiling rear' depending on whether you are front or rear projecting. It should all be on page 29 of the manual.
Hope this helps
Matt.
Apr 01, 2008 | BenQ PB6110 Multimedia Projector
BenQ 6110
Hi there
If your S-Video connction id fuzzy - try another S-Video cable and if the problem stil occurs you will have to replace the Mainboard
Mar 17, 2008 | BenQ PB6110 Multimedia Projector
Benq pb7220, can't find composite video source
Hi there
You'll see at the back of this projector where the composite input is there is two holes with screws. Unscrew it and remove the part.
It looks like a DVI connctor. Check if all the pins is in order. If you can't see anything wrong - buy just that part and replace it.
It is VERY cheap to replace.
Mar 15, 2008 | BenQ PB6110 Multimedia Projector
Resetting the lightbulb in my benq projector
press and hold exit button for 3 seconds or more and OSD will pop up, then follow instructions
Dec 28, 2007 | BenQ PB6110 Multimedia Projector
BenQ PB6100
Hi there
If your Projector is not working in colour , take out the lamp and check if the colour wheel is broken.
If not broken you will have to replace the Mainboard.
Dec 07, 2007 | BenQ PB6110 Multimedia Projector
Unclear, fuzzy image
Hi there
Try another S-Video cable , if the problem still occurs you will have to replace the Mainboard
Nov 07, 2007 | BenQ PB6110 Multimedia Projector
Problem in logic card of the projector
BenQ has support in India: http://www.benq.co.in/ India India Customer Help Desk 1800-22-0808 (Mon to Fri 0830-1730hrs) Service ID service-In@BenQ.com Sales ID SalesEnquiryIn@BenQ.com (Lunch time : 1:00-2:00hrs PM) But this model is out of production so you may have trouble getting parts.
Sep 28, 2007 | BenQ PB6110 Multimedia Projector
BenQ PB6110 Multimedia Projector Logo
129 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
