Question about Apple iMac 24" Desktop
Hard disk icon disappeared from desktop
New user of iMac (model XC4571 apple aluminum 20") The hard disk icon which was origionally on the top R/H corner of the desktop has dissapeared. I must have clicked or done something wrong. Please help!
How can I restore the hard disk icon to my desktop. ?
  • new iMacuser Oct 22, 2008
    Thanks flyscan, your solution was clearly explained and effective in restoring the hard disk icon to the desktop for, "new iMaccuser"
  • jackattack94 Jan 31, 2009
    I accidentally made one of my hard disk disappear on my mac pro by pushing
To add the hard disk icon back onto your desktop, first click the "Finder" button in the dock. It is the dark and light smily face icon at the end of the dock.
Next, click the "Finder" menu item at the top of the screen and then "Preferences". In the "Finder Preferences" window that opens, click the "General" button. From there you can select what system items appear on your desktop. You can click "Hard disks" to re-add the hard disk icon.
Posted on Oct 21, 2008
Hi !!! I use ibookG4 and my finder sometime appeared sometime disappears also hard disk icon disappears. anyone have solution for this problems
Posted on Mar 23, 2010
Wont boot on its own, wont boot with install disc,
As the hard disk appears to be showing up when you boot up using the install disc, I would suspect that the system is somewhat corrupted. You could reinstall the system again and if you are happy starting from scratch and wiping the hard drive select this option failing that and there is some data on the imac you could install using the preserve user data. A fresh install should sort out any problems. Hope this helps.
May 18, 2010 | Apple 20" iMac Desktop
Apple imac g5 desktop 17 boot disk boot hd failure. Reboot the pc is to click in c to begin to read the cd of I restore and nothing is only an icon to blink
It sounds like your hard rive has failed. You could if you can ask someone for a loan of a disk utility such as disk warrior to check the hard drive. If it has failed have a look at the following websites on how to replace it
http://www.dtgeeks.com/index.php/features/tutorialview/imac_g5_hard_drive_replacement/
or
manuals.info.apple.com/en/imacg5_17inch_HardDrive.pdf
Oct 28, 2009 | Apple iMac G5 Desktop
Is the Western Digital external drive working?
1. Restart your Mac with the drive plugged in. 2. Use Disk Utility (/Applications/Utilities/Disk Utility) to look for the drive. 3. If it isn't mounted, select the disk in Disk Utility, select the Disk First Aid tab, and click Repair Disk.
4. Look in the Finder Preferences and make sure that you haven't disabled the display of disk icons on the desktop.
Oct 16, 2009 | Western Digital Passport 320GB External...
When i turn on my imac it does not go to my desktop just stays on with a floppy disk icon on it
I am assuming that you are running OX S so it sounds like the system is corrupted. What I would do is to get your instal disk and boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work.
Oct 15, 2009 | Apple iMac M6709LL/B Desktop
When my imac g4 tries to bootup it shows a folder icon
It sounds like the system is corrupted. What I would do is to get your instal disk and boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work.
Oct 03, 2009 | Apple iMac G4 Desktop
Remove the screen from iMac aluminum 20"
AMFITEATAR - Naucni portal - Upgrade your iMac 20" or iMac 24 ... This link will have what you need to remove the front cover off the LCD screen. It then goes on to show you how to get to the hard drive.
Jan 20, 2009 | Apple iMac 24" Desktop
Hard disk icon disapeared
checked that the column of macintosh HD icon is ticked in finder
I recommend that you trash the file Users > <yourname> > Library > Preferences > com.apple.finder.plist
Regards
Samson Ved
Dec 08, 2008 | Apple iMac 24" Desktop
Hard disk icon has dissapeared from desktop
Try this. Click on the desktop Then from the "Finder" menu choose "Preferences". In the "General" tab, make sure all the boxes are ticked - especially the one for "hard disks".
Oct 21, 2008 | Apple iMac 24" Desktop
Apple iMac 24" Desktop Logo
3,629 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
