Question about Motorola Mobility RAZR V3
Phone won't power on or take a charge
I did nothing but turn off my phone - it had lots of power when I turned it off and now nothing. It won't even take a charge when I plug it in. I didn't drop it or submerge it in water- NOTHING! Any ideas? Thanks
  • Anonymous Jan 08, 2008
    Can't charge dead battery
  • pnguinlovr Jan 14, 2008
    Phone worked fine one day, then wouldn't turn on the next. When I plug in the charger, the screen turns on and off every few seconds but it doesn't appear to be charging.
  • 175 Answers
You need to check your battery capacity if its below 3v then you need to get it to its standard voltage.
Posted on Jul 17, 2006
How I can "get it to its standart voltage"?
Posted on Jan 09, 2008
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
My LG 4G LTE won't turn on even though it has been charging for hours.
do you have a universal travel charger? and use it to charge your battery for about 4 hours. or buy a new battery.If it is not ok, your phone is in short-circuit. go to service center
Apr 15, 2013 | LG Cell Phones
Incredible 2 phone won't turn on
your phone is not supported 32gb memory card that's why your phone is totally hang so if u want to fix it you have to update your software and go to a service station
Jul 09, 2017 | HTC Droid Incredible 2
The phone won't turn on
Try replacing the rechargable battery inside that phone.
Jan 12, 2013 | HTC Amaze 4G Smartphone T-Mobile
My droid incredible2 won`t turn on. how do i reboot it
Charge the phone for 10 minutes.
Press down the volume up button and hold it and then press the power button for a few seconds . The device will restart.
Dec 16, 2017 | Cell Phones
My phone charges but never reaches the stage where message says "your battery is full now", even if i leave it overnight to charge. then when i turn the phone on, it's life is only a couple...
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 06, 2011 | Nokia 7230 Cell Phone
Samsung P520 ARMANI Cellular Phone armani phone won t start
i got the phone of ebay its a copy from china ive only had a week and wen i go 2 charg it sum times it will and other times it wont but even wen i try and turn it on it comes on for 3 seconds then goes strait off
Oct 07, 2008 | Samsung P520 ARMANI Cellular Phone
Battery charge is finished very soon without even using it( in about 5 hours)
The proper way of charging the battery on your phone is by waiting for your phone to indicate that it's running out of powe but not completelyr, if you frequently charge your phone even if it's not yet necessary(battery life indicator show half-way) the ability of the battery to store power will deminished hence the battery life is shorter. Last resort would be trying another battery unit to test if it's your battery of your phone that's causing the unsual battery drain.
Or you can try the following steps on conserving your phones battery life;
  • Turn off your Infrared and BlueTooth when not in use. Even when they are not in use, they do keep drawing power looking for signals.
  • Switch off the vibration alerts. Vibration causes a lot of power usage thereby making battery drain fast.
  • Re-adjust your screen brightness to around 50%. Screen power is another silent killer.
  • Usually, presetted Backlight durations are of pretty high order, this can be readjusted to get more from your battery. Try reducing the Backlight duration.
  • Often we don’t understand that playing games requires Light, Sounds and Shakes. This in turn leads to tripling of battery drainage.
  • Lower Ringing and other message sounds. This too helps saving a lot of battery.
  • Finally, do charge your battery before it gets drained fully. This enhances battery life.
May 05, 2008 | Sony Ericsson K800i Cellular Phone
Won't Charge or Turn on
First try drying out your phone for a day or two with lots of dry moving air gently blowing past and around it, the phone must be unplugged and battery removed during this process, then once everything has been dried try charging the battery in another phone just like it, if it charges and see it it will power the phone, if the battery works put t back into your phone and try to turn it on. If it doesn't work in your phone but it does in another then its the phone, if the phone works with another battery its the battery but dry them both totally first, even a few tiny specs of moisture can screw up your phone when power is running through it, so be careful. Cheers!
Mar 02, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
245 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
