1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Thats the correct proceedure for the H82 series toshiba. Your eprom may be defective if you cant access the service menu
The eprom is the main processor that has all the service menu parameters programed in. Its a large IC with numerous Pins which is very difficult to replace without the proper tools and it also needs to be reprogramed after installed . This may be better suited for a Toshiba authorized service center to repair.
KEY FUNCTION IN THE CONVERGENCE ADJUSTMENT:
Lord BACK UP DATA: 1 button
Up : 2 button
Selet Green color: 3 button
Left : 4 button
Blinking of cursor ON/OFF: 5 button
Right: 6 button
Adjust mode ON/OFF: 7 button
Down: 8 button
Vertical stripe ON/OFF 9 button
Erase Green line: 0 button
Erase Red line: 100 button
Erase Blue line: ENT button
12. Press “7” button to memorize the adjusted states.
At this time, picture changes for about 1 second.
13. Press the TOUCH FOCUS button when "PLEASE PUSH
TOUCH FOCUS" is displayed on the screen.
14. TOUCH FOCUS CALIBRATION MODE is executed.
15. It returns to the normal screen after displaying
"CALIBRATION FINISHED".
Glad I could assist you with it, please rate my responses to your request. Thanks
slinteriors
Thanks if you need further assistance please let me know, and thanks for the rating
That would be the skew adjustment
Thank you..........do you know that the skew would be called in the menu i cant find it
this does not work............i have tried it before
the provlem possibly is the original remote control for this tv the mute button when pressed says 1/2 mute then u press again and it says mute.........not sure if that makes a difference but the procedure you just showed me does not work using the original remote
are their alternative methods? is the procedure you jsut showed specific to this tv?? or just general
and by the way the tv needs to be on correct?
with tv on
i have tried pressing mute 2 times on remote
press mute 1 more time and hold
then press menu on tv while still pressing mute on remote
correct?
this does not work
thank you yes it does not work with my tv for some reason
what us a eprom and is it repalceable and if so how would i do it
thank you..........my tv is fine but it just needs a little fine tuning.........the auto converge doesnt work well........i have to manually converge which this model has in menu thank god lol to get the pic pretty good but there is just a small distortion in the bottom left part of screen maybe only 2 inches in that needs to be adjusted in service menu....from my expericen auto converge on most tvs does not work well at all........
oh well i can live with it i got the tv for free..........
thanks
i want to make sure i was doing it right
with tv on
hit mute button 3 times on remote and hold on 3rd time
then hit menu button on tv while still holding mute on remote correct?
hey it does work...........you have to hit all bottons with no time in between..........
i was doing it slow before.............thank you so much
ok i got into service mode and hit 7 to get to convergence grid.........now what i have is a large grid with a blue small box and i can change the box to green and red and can move the box around but do you know how to actually adjust....what keys to hit to move the RGB up down left right converge....the directional arrows on my remote dont do anything
thanks i got it to adjust i was trying to use the arrow keys........
now how do i save what i did??
i havent turned the tv off yet........and dont want to lose the adjustments i made
thank you.........can you now please tell me how to save the data i changed
i found out how to save it.........thank you so much the picture is perfect now..........
i did something different i hit the 1 key and then it says hit enter to load backup data
i did that and it worked..........
is that correct also?
im afraid to hit touch focus at all since whenever i do touch focus it makes the alignment all out of whack
one more question
the tv pic is great now but the lower left corner is a little too low and the upper left corner is too low.......you can only really notice it when watchin ESPN with the scrolling scores on bottom of screen and sometimes top of screen.....seems like i need to move the left side of the screen up a little
how can that be done in service mode??
what adjustment is avail if any
