Question about JVC HR-A57 VHS/S-VHS playback VCR
HR-A37U remote won't work
The remote for this VCR will not work all of a sudden. I cannot turn on the power. It will work to turn on/off the TV if I turn the TV button on on the VCR remote and hit power but it will not turn on the VCR.
  • Der Arzt Dec 09, 2008
    I have a universal remote for vcr's; however, the codes posted in the booklet will not work my JVC HR-A57U. There was 8 codes in the booklet. There must be more codes and how are they accessed?
    thanks
    drw
  • trixytee34 Dec 10, 2008
    I am unable to locate the codes to use for my universal remote. hlep? I have an HR-A37U VCR
    Scholar:
  • 74 Answers
It's not unusual for remote controls to stop functioning either partially or fully. To determine where the problem is, you will have to go through a process of elimination. The easiest way to find out where the problem lies is to purchase an inexpensive universal remote at a nearby store. Try the different codes and see if you can activate the VCR. If it works, you have the option of keeping the remote or returning it for another one if you cannot access all the functions of the VCR. I have seen exact replacements online for under $20.
If it does not work then the trouble is most likely in the VCR itself, unless the proper code could not be found in the universal remote, in which case you need to try another brand or model.
The only other suggestion I have for you would be to unplug the VCR from the AC power for at least 5 to 10 minutes and then plug it back in and try the original remote again.
I hope this helps, good luck.
Posted on Oct 21, 2008
Why wont my vcr turn on?
There is a lot of things that could be causing this. Since this is a unit that is obsolete and no parts are available, it would be a component level service event. IF you have not taken the unit apart to check internal fuses then that is the place to start. Then you look for obvious part failures like burned marks, failed capacitors that have leaked or burst.
Jan 28, 2018 | JVC HR-VP78U VCR
The Vizio TV won't turn on all of a sudden
Are you trying with the remote and the power button on the tv? The batteries might be dead in your remote if you haven't tried the power button on the TV.
Feb 15, 2013 | Televison & Video
Need a remote for JVC HR-A592U VCR
Try website like Remotes.com to buy the VCR original remote.This site sell all DVD/VCR,DVD, VCR,TV and all electronics original and clone compatible remotes.
Sep 01, 2011 | JVC HR-A592U S-VHS VCR
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
My 1.5 IR Dish remote has all of a sudden stopped working with our Sanyo tv. I've changed the batteries. When I push the power button it will only light up the VCR button if anything at all. Our other...
sandyannsamp
If the VCR button lights up when you press the Power button, you are not in the correct mode to operate the TV. If the remote is programmed correctly, when you are in SAT mode, you can press the large RED button to turn your receiver off/on. The RED TV button will turn your TV off/on. I have provided links to program your remote to your TV again. I have also provided codes for your Sanyo TV.
Instructions to program your remote to your TV (begin with step 6):
http://www.dishnetwork.com/SupportSection/remote-setup
Here are the TV codes: 590, 683, 589, 542, 652
I hope this helps.
Ray Calo
DISH Network
Nov 18, 2010 | DISH Network IR Remote Control
The remote isn't working (and, yes, I tried new batteries--a couple of times). I need to hit the "TV/VCR" switch. I don't see that same button on the VCR. How can I switch from TV to VCR (and back) when...
I ran into a very similar problem with a TV that I had that did not have a TV/VCR button on it. You HAD to have a remote to change it and the remote for the TV had been LONG lost. The solution was to go to Target or Walmart, and pick up a cheap universal remote. Make sure that the universal remote has a TV/VCR button on it and when you get the right code plugged into the remote it will function just like the original remote.
Mar 27, 2010 | JVC HR-DD750 VHS VCR
VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
Jun 11, 2009 | JVC HR-XVC27U DVD Player/VCR
RCA VR678HF display reads, "LOCK." Nothing will work!
Held down on-off button on remote control for 10 seconds.
Dec 05, 2008 | JVC HR-S9400 S-VHS VCR
JVC HR-A57 VHS/S-VHS playback VCR Logo
152 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
