Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Water running down door
I have water that seems to be pooling under the removable tray on the water dispenser. If you remove the tray and put you hand in you will feel a gap on the anterior side. I think somehow water is getting in there. Then is is seeping our of the trim and starting to bubble the paint. I wiped it off think it was dirt and paint came off. Now daily there are two thin lines of dried water (white lines) coming out from under the trim. Could the water be coming from somewhere else? Have you heard of this before.?
Thanks Leslie
  • 1,543 Answers
Yes, I've seen this. Just seal that gap you found with clear silicone (and try to keep the recess from filling and overflowing).
Posted on Oct 21, 2008
How do I remove the ice water dispenser cover on my whirlpool conquest
Remove the drip tray. Using all your fingers from both hands press down on the bottom of the cover, and at the same time pull away from the door. The top of the trim has tabs that set behind the dispenser housing. To replace the trim, set the upper tabs behind the housing and press in moving down both sides till you get to the bottom.
May 02, 2017 | Whirlpool Refrigerators
Water leaking from door when cold water dispenser being used
Hello Frank,
The line that runs from under the freezer door and connects to the dispenser is cracked or the connector is cracked. By removing the lower hinge cover ya should be able to see where the line connects to the door and see if it seems to be cracked and leaking their,if that connector is good then the line inside of the door is leaking..in some cases depending on brand the line is easily replacable without having to dis-assamble the entire door
GENE
Nov 11, 2011 | Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Water &detergent are standing in the soap dispenser. I would like to remove the entire tray that holds detergent,bleach,softener, but have lost my manual and don't remember how to remove it.I have an...
Most washing machines that I am familiar with have one of two possibilities of getting the soap dispenser out.
1. Look for a "knob" or something like when you put your hand (palm up) inside the dispenser, if you hit a "knob" push it and pull the dispenser out at the same time.
2. Pull the dispenser slowly out of its "home".
When the dispenser is out and wash in warm water, under the tap.
Good luck
Dec 27, 2010 | Washing Machines
Whirlpool sidee by side. Ice seems to be getting stuck in dispenser. Push for ice and you can hear a grinding sound but nothing comes out. You can put y our hand up and pull ice from the dispensing tube....
chute is probably clogged with ice. Remove ice storage container, look into chute (from inside) and see if you can see a build up of ice. If so be careful chiping it out. You may want to stuff a moist hot hand towell down in there first to soften the ice bond with the plastic, then while holding a bowl under the delivery area, try to carefull chip it out.
Mar 10, 2010 | Whirlpool GS5SHAXN Side by Side...
Bottom of fridge collects water
Hello there:
I have written a few steps for you to follow and try ok?
  1. Manufacturers have different ways to dispose of the water created during automatic defrost cycles. The most common design routes the water down a rubber tube on the back of the fridge to a tray beneath. This tube often gets plugged with breadcrumbs, peas etc. and can generally easily be removed and cleaned.
  2. Make sure the end of the hose is sitting in the defrost tray.
  3. If your hose was not plugged and you have found water running down the back wall inside the fridge or a pool under the bottom crisper has formed. Check if there is a small funnel located on the back wall near the top inside the fridge. It can also get plugged; you can use a small wire and work it in and out of the hole.
  4. Some designs do run the water down the back wall and have a drain hole under the crisper, make sure it is not plugged.
I hope that this has been verry helpfull for you
best regards michael
Nov 06, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water remains under rubber seal. Water too high in bleach dispen.
Did you try taking the dispenser tray apart and cleaning it? The exit ports tend to clog over time. Best thing I have found is to remove the tray at the end of wash day, rinse it out, dry it and put it only partially in the machine, thereby allowing air circulation. Some water will always remain at the end of the wash cycle...inherent in the design.
As for the gasket, you'll have to wipe it down at the end of wash day and leave the door open to dry everything out. I leave mine open all the time.
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
GE Side by Side Refrigerator seeping water onto door
Hey, thanks for the photos. Have seen this problem before. Seal the recess area, at the front edge and the front corners, with a little clear silicone, to prevent water from getting behind the stainless steel door panel. I've heard people say to seal the rectangular holes along the bottom side of the door panel recess cut out also, but that shouldn't be necessary, as if you still had water behind the panel, it would just then seep down behind the SS door panel and continue to cause problems. The real cure is to keep water from getting in there in the first place.
May 03, 2009 | GE GSS25QSTSS Stainless Steel
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
70 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
