Samsung hcr5245wx/xaa rear projection televsion. words and picture on screen are slanted. picture not square with screen.
  • gocean88 Mar 10, 2009
    I have the same coloring problems and it started from they time I purchase my TV, I called Samsung and they told me that it was because Bransmart did not service my Tv properly till this day I have not been able to fix it........it a blue and red color problem because theyr are not merge together.
5 Suggested Answers
BMW Rider
  • 232 Answers
SOURCE: 53UDX10B 53 in. Rear Projection "3D vision"
the convergence IC`s and associated resistors have to be replaced, do not repeatedly push magic focus or the alignment after the parts change out will take longer which of course means higher repair bill, good luck
Posted on Nov 27, 2007
  • 74 Answers
SOURCE: toshiba theaterview 50in rear projection tv
Look at it on the QVC channel where you have boxes with straight lines. If any of the 3 colors are bowed and 1 inch off, then it needs parts inside. If the colors are straight and only 1/4 inch off, you can adjust it. Using the remote, in the menus find convergence to adjust. Your user manual will explain it. At WWW.Toshiba.com you can download the manual if you do not have it.
Posted on Mar 24, 2008
easyab
  • 132 Answers
SOURCE: Samsung rear projection television HCN4226WX/XAA
Dead Samsung
I don't recommend working on the TV unless you have some experience and knowledge relating to the safety issues and electronic repair. Most rookies will not successfully complete the repair and probably do more harm than good.
Sometimes when the convergence chips fail, the TV senses the changed load condition and shuts down.
Unplugging the blue, red or green convergence connector on the convergence board removes the overload condition if the IC is shorted and allows the tv to run, with one color missing.
This is done with the tv unplugged. Then plugged in and turned on to see if it starts. Turn off immediately if you here it start.
Now you know if convergence failure caused the shutdown. You can repair the convergence circuit if that is the problem.
If this has no affect, then you could have a number of different faults in Vertical output, Power Supply or HV circuits that require the expertise of a qualified service person. This would be a bench repair in most shops.
If you live around Calgary, Alberta try me instead:
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
easyab
Posted on Jun 27, 2008
ladywinn
  • 5138 Answers
SOURCE: samsund rear projection tv
I hate to tell you this but its a good chance its your light engine,if the dots begin to spread over the TV it is the Light engine.
Posted on Jun 23, 2009
  • 8457 Answers
SOURCE: I have a Samsung rear projection hcr4755wx/xaa and
Ur convergence is dead.U know how to solder?Tries these websites,Tv Repair World.com or Ebay.com.Buy a convergence kit,use the parts in that kit.
Posted on Oct 01, 2009
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Samsung hcr5245wx/xaa is mostly red and can't get it focused back in. How do I fix
Hello, it sounds like either the coolant on the face of the crt's* has mildewed, or the crt's* are going bad. *crt's are the cathode ray tubes, or picture tubes.
Jan 30, 2015 | Samsung Televison & Video
Samsung hcr5245wx xaa
It sounds that the horizontal output section circuit has the fault. The horizontal output transistor might have burned out. Check it.
May 23, 2013 | Televison & Video
What is your issue or problem with this set?
Mar 14, 2012 | Samsung Televison & Video
My tv suddenly went to red and green double vision. Looks like 3D without the glasses. I want to repair myself. Samsung 1080i model HCR5245W. MFG July 2005.
That would be your Convergence, Encompass Parts Distribution
has Convergence Module for $50.00 that goes to a HCR5245WX/XAA 1-800-638-3328
Or you can just replace ICs will have STK on them
Mats has ICs 1-800-628-1118
Sep 27, 2010 | Televison & Video
Doesnt line up anymore words are kinda slanted
Your convergence Integrated Circuits (IC) are going bad which is a common problem for all Projections no matter what brand. Can be fixed by your local repair shop for no more then $250.00
Jan 20, 2010 | Hitachi 50FX20B 50" Rear Projection...
Slanted Border- Projector image is not square
Is the image slanted on the bottom as well?
Make sure the projector's throw is pointed directly at the target ie. screen or wall etc. there's not much else it could be.
Jan 10, 2009 | InFocus ScreenPlay 4805 Multimedia...
Samsung LCD TV HCP4363WX/XAA Black screen no sound.
check out the link below ... sounds like a similar problem:
http://www.dslreports.com/forum/r20889230-Samsung-LCD-TV-No-Picture-but-has-Sound
Aug 21, 2008 | Samsung HC-P4241W 42" Rear Projection...
Televison & Video Logo
253 people viewed this question
Top Televison & Video Experts
Electro Med Services...
