I recently notice the the output from my receiver seems to be reduced. When playing music I would have the volume set at -.50. This was plenty of output for easy listening. Now I find that this setting appears to be putting out less sound. I've checked all connection, all channels, each individual speaker and tried different sources of input (radio, cd, dvd)but have the same results. I can turn the volume up to get the output but am concerned on the cause of the reduced output?
-   About a month ago had a small smell of burnt electronics and thought it was from the new TV I bought, but nothing was wrong. Yesterday heard my power regulator for the computer complaining (beeping) as if either I got a huge voltage spike in my electricity (or maybe something shorted somewhere) but the lights or circuit breaker of the house did not go out. Then at night went to listen to receiver and I notice the it was working partially. This is, everything works, sound through all channels, etc BUT it has lost VOLUME this is when volume at 35 out of 60, it sounds like 10 out of 60. Also it lost definition, the sub for example seems to have frequency missing. Could it be that some audio/output amplifier IC burnt? How many IC amplifier does this unit have? If one burnt would the symptom be as describe above? Am I in the right direction to what is my receiver problem? Any help would be appreciated. Thanks-   hillbillykid
I'm not sure how long you've had this unit but over a period of time speakers being run at high output can lose some of their bite. Have you changed the furnishings in the room concerned. Heavy drapes and softer carpet and furnishings can attenuate your output. Are you playing the same recorded medium? Many CDs are compressed to maximum to please the headbangers whilst others can be natural and completely uncompressed, thereby giving lower volumes on some recordings.
Are you sure the amplifier can breath. No buildup of dust and fluff on the internals. Bad air circulation can cause heat sensors to attenuate output in some amps too. Are you sure the bass/mid and treble are in their correct positions? Are you sure there's no inbuilt attenuator which may have been pushed in error?
Does your unit have presets such as Rock, Classical, Disco etc? These can cause major output variations. Also many amps have inbuilt graphic equalizers which can be saved. Are you sure someone hasn't used it to cut back cartain frequencies.
If the outputs are protected by fuses, remove then and replace them with new ones. Over a period of time fuses can become stressed due to beinf constantly warmed up and then cooled down. Occasionally ther can appear to the circuitry to be resistors and load the output down.
Apart from these tips maybe a trip to the doctor but before doing so, double check your wiring and connections etc.
How do I connect Playstation 3 to Yamaha RX-V630. I tried the front V-Aux inputs and nothing...
(More)
How do I connect Playstation 3 to Yamaha RX-V630. I tried the front V-Aux inputs and nothing happens.
how do i reset sound settings, my dad was doing stuff to try to set it and now not all speakers have...
(More)
how do i reset sound settings, my dad was doing stuff to try to set it and now not all speakers have sound
Is there a 'common/master' output that I can connect a set of wireless headphones to? They (Acoustic...
(More)
Is there a 'common/master' output that I can connect a set of wireless headphones to? They (Acoustic Research AW-791) have connections for RCA, Optical and digital cables. Thanks
My RX-V630RDS amp (6 years old - has worked without problem for a long time) has recently started...
(More)
My RX-V630RDS amp (6 years old - has worked without problem for a long time) has recently started playing some sound sources very strangely. It is often as if part of the audio signal is missing and the problem is more exagerated on some DSP programs - for example on Concert Hall and Jazz Club all you can hear is the reverb effect and none of the original signal. And on a DTS source from the DVD on the Auto DTS movie settings you often find part of the music track missing. It has me completely stumped! Has one of the ICs blown perhaps? Anyone seen anything similar? Any thoughts so much appreciated. Thanks.
I found out that my receivers right channel was not working and I switch it from channel A to B at...
(More)
I found out that my receivers right channel was not working and I switch it from channel A to B at first it was working fine but after few days it stoped working to .
