How do I align the camshaft/flywheel when reassembling? And the small plastic "banjo looking piece" on the bottom of the camshaft,which I assume is the oil pump for it,is tapered on one side,does that side face the bottom or up towards the camshaft?
the crank gear has a marked tooth and the cam has a mark between two of the teeth - the other piece is the govener gear which meshes on the cam - it must be aligned so it contacts the gov arm - without a mod # im not sure which style gov gear you have . there is no oil pump in an engine of that size
my playstation 3 had fallen of the top of the tv. when i turn the playstation 3 on the power light...
(More)
MY PLAYSTATION 3 HAD FALLEN OF THE TOP OF THE TV. WHEN I TURN THE PLAYSTATION 3 ON THE POWER LIGHT TURN RED THEN IT CHANGE TO YELLOW
(More)
Simer Sump pump from 1995 appears to have failed. Plugged into GFI outlet and it immediately kicks...
(More)
Simer Sump pump from 1995 appears to have failed. Plugged into GFI outlet and it immediately kicks out the breaker. Unplugged, took the pump out, took off the housing. Impeller not jammed. Put it back together. Still not working. Do I need a new pump or a repair? Basement starting to flood.
