Danby DDR451 Dehumidifier
Problem for Danby DDR451 Dehumidifier
Does not turn on
By danby1 on Jul 07, 2006
I turned off the machine, emptied out the water, put the tank back in and turned the machine on. Nothing happened accept the power light flashes. I unplugged it and let it sit overnight but still nothing happens
Same Problem
Apr 21, 2009
-   Same thing with me. I bought the unit. Ran over night. emptied out the bucket and ....the compressor would not turn back on. The fan does run however.
took it back and got a new one.
Plugged that one in and worked for one bucket. Then the compressor would not come back on.
I have a 30 yo dehumidifier that works fine in the same outlet.-   Guest
Sep 01, 2008
-   CAN SOMEONE ADVISE ME WHERE A I CAN GET A SERVICE MAN TO LOOK AT MY GOLDSTAR DEHUMIDFER '/;, I AM LOCATED IN STATEN ISAND NEW YORK-   RICH200
Aug 25, 2008
-   THE MACHINE HAS STOP WORKING.I TESTED THE OUTLET WITH ANOTHER APPLIANCE AND IT WORKS FINE-   RICH200
Aug 25, 2008
-   THE MACHINE WORK FOR A FEW MONTHS THEN DECICED TO STOP.I TESTED OUTLET WITH A DIFFERENT APPLIANCE & IT WORK FINE.-   Guest
Aug 25, 2008
-   THE MACHINE STOP WORKING & now wont go on.II CHECK THE OUTLET WITH A DIFFERENT APPLIANCE & IT WORKS-   Guest
Best Solution
posted on Jul 21, 2006
Helpful)
hardrocko
Rank: Guru
Rating: 85%, 922 votes
All dehumidifiers have an interlock to prevent them from running when the tank is out. This is to avoid a mess with not tank for the water to collect in. I would say that your interlock switch is in a position which is telling the machine that there is no tank in the unit. Take the tank back out and look into the space with a flashlight to find the switch. It could be on the bottom or the top. Your operation manual might be helpful in locating the switch. Once you find the switch check it for operation. It should move or depress when the tank is put in. It probably is jammed and you will have to determine whether it can be fixed or you may need to replace it. If it moves freely then it is probably defective and will need to be replaced. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Danby DDR451 Dehumidifier
Questions and Unsolved Problems for Danby DDR451 Dehumidifier
Do you recommend Danby DDR451 Dehumidifier?
Answer
Answer
my humidifier will is not lighting up and seems like it's not getting power, fuze is okay and I... (More)
Answer
i have a dandy dehumidifier model ddr451. it is approx 5 or so years old. ever since i got it will... (More)
Answer
How do I know my DDr451 humidifier is set for direct drain?
Answer
I purchased a Danby dehumidifier lastyear and it worked great for a while. Now after I empied the... (More)
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Aug 25, 2008
I I TURN ON THE SWITCH AND NOTHING HAPPENS IT WAS WORKING FOR A FEW MONTHS . IT JUST DOESNT GO ON ANYMORE. THE LIGHT DOESNT COME ON & I CHECK THE OUTLET ,IT WORKS WITH OTHER APPLIANCES/
Comment by Rham12, posted on Jul 06, 2008
Hi, My Dehumidifier is 1 year old and last month doesn't turn off, the only way was unpluged the unit from the receptacle, now doesn't turn on, I alredy tried the red bottom (Interlock) and nothing.
Comment by Guest, posted on Jun 25, 2008
will not turn on
Comment by Guest, posted on May 10, 2008
Red button inside the unit I had to put tape on it to hold it down in order for the unit to run. Runs like 4 or 5 min. then cuts off. Over and over.
Comment by huggablemonk, posted on Dec 16, 2007
I have a 45 Pint Dehumidifier, Has worked very well for quite a while, now, after emptying the tank, it won't start up. Fan comes on and then shuts off as if full. Sometimes if you remove and replace the tank, several times , it may stay on. not sure if it is a bad sensor, or switch. Once it is running it will shut off when full. Filters are clean.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DDR451 Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1200
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
