Question about Sony Grand WEGA KF60WE610 60" Rear Projection Television
Blue dots on screen
Blue dots cover entire screen and seem to be getting worse
  • Anonymous Dec 29, 2008
    Same problem - Sony Canada basically says "tough" - $5,300 TV that is four years old and we get "tough" -
    Optical Block plus labour installation and taxes over $1,000 to repair -
    We're not done with this yet!
  • Anonymous Jan 29, 2009
    Same problem mines 2 years old I thought maybe it was dust on the bulb...since it is a rear projection?
    Problem Solver:
  • 11 Answers
You have a bad optical engine i have the same tv...........its a manufacture defect
900.00 part
Posted on Oct 21, 2008
Can a blue dot on a tv screen get worse or stay the same.
One little blue dot is not enough to warranty the television. If you read all the documents on the set, it will tell you that some imperfections in the display are allowed. The good news is that it wont get any worse
Feb 23, 2015 | Element Electronics Element 50" Class...
There is a red dot near the center of my Vizio tv screen, what is it?
if just a single tiny dot it is a bad or defective pixel in the front panel-usually there from first time the unit is powered up but from a distance may not be noticed--almost never gets worse or increases in size. Unless set is under warranty do not worry about is as a Panel(entire front screen unit) usually costs more to replace then the entire TV.
Apr 08, 2012 | Televison & Video
Blue hue on left side and tiny blue dots on most of screen. The dots seem to dissapear and reappear if you look closely. I changed bulb about two months ago and it seemed to just get worse since then.
The blue hue on the side and dots are most likely a damaged (burnt light or optical light engine).
This is very common and you may want to contact Sony as there were programs for some models even if OUT OF WARRANTY.
The lamp in the set shines into a a L shaped engine with baffles and lens (red, green, and blue segments) and Blue is closest to the heat from the lamp and usually is the first place to get this type of damage.
I do not enjoy giving bad news but this is what I am sure is your problem.
If this information and a honest answer told you something you did not know rate this solution as very helpful as I do this here for free.
Aug 11, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi there,there is a ring of blue dots
clean the lense of your projector, dirt or moist of water may be possible reason
Feb 18, 2010 | Canon LV-S3 Multimedia Projector
Blue section (corner) and blue dots
This set has no internal manual adjustments for color. The Tracking or B&W balance is accessed via the service menu. I don't suggest you attempt to adjust without instrumentation. the trouble with your set is not an adjustment. Most likely the Optics are at fault. This model has had issues with filters in the optics being destroyed over time by the lamp. The blue haze will get worse and continue to grow over the whole picture. The only option is to remove the Optics (light engine) and sent it out to be rebuilt.
Apr 14, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
HDTV is getting blue dots and the right side has turned blue
These issues are problems in the light engine (optics block)
the dots are called "starfield" and the geometric is "roadmap"
replacing the light engine will fix the issue. for awhile, sony was extending the warrany on the engine for these issues only, but that may have expired.
part # A-1606-008-A
Nov 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Kf-42610 blue hue and blue dots on screen
Hi Guys
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
Blue dots
You have a bad blue LCD in the light engine. Replacement of the light engine is the only fix and it usually will continue to get worse over time
Feb 13, 2007 | LG RU-44SZ51D 44" Rear Projection...
Sony Grand WEGA KF60WE610 60" Rear Projection Television Logo
167 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
