Question about JVC AV-36890 36" TV
Screen goes blue and returns if cable cord moved
I have replaced the tuner with a JVC part. Picture and sound are great then suddenly goes blue and squeals. If the cable line is moved/wiggled, the picture and sounds will return to normal. All the cable line has been replaced as well. Had a in home repairman tell me it was the tuner....but of course, it did not fix it.
Your help would be GREATLY appreciated.
Thanks!
  • 1 more comment
  • aanderson113 Oct 21, 2008
    FYI...TV has had a direct connection to cable as well as a DVD player connected. The above issues still occurs.
    There is no cable box in the line. I am assuming the tuner card is different than the tuner itself. If so, where is the best place to find the part number for ordering? Thanks!
    Thank you for the info. I have a friend who can repair it as long as I have the correct part. Would this be called the Electronic tuner part CEEK280-A01? I have replaced CEEK280-A02 (Tuner).
    Brigadier General:
  • 6,966 Answers
Offhand, I suspect that no replacement part would be needed. Initially, the blue display is significant, it tells us that there is no "intelligent" signal to be processed by the video board and therefore goes into "video mute" mode. Your other post "squeals" + cable line moved/wiggled = picture & sound normal but all cable line replaced could possibly indicate that the connectors/jack might be the issue or the board itself. Pls have the reverse of the PCBs (boards checked for loose or cold solder). Additionally, it might also help to verify that the boards are not loose or overly tightened causing bottom grounding, flexing or warping.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 21, 2008
    Genius:
  • 1,847 Answers
Try do the same thing using the dvd or cd player plugged in.
  • 1 more comment
  • Legin Varghese
    Legin Varghese Oct 21, 2008
    if it works fine then the cable box is causing the issue.
    else
    it is the tuner card inside the Tv.
  • Legin Varghese
    Here the web site where you can order parts online.
    http://www.partstore.com/Model/Matsushit...
  • Legin Varghese
    If you technical enough to change the tuner card then only do it else take help of an expert.
We recently purchased a vizio 47 in lcd tv. sound goes out , returned that tv, now the replacement is doing the exact same thing. we have a great picture, just no sound. if we change the channel we get...
The cable box have problems,tries replacing the incomming broadcasting connecting wires,that goes to the tv Tuner signal board.If u still have the same problems,call ur cable company for a cable box replacement.
Mar 21, 2011 | Vizio VO47L 47 in. LCD TV
Blue screen
bad connection but where need tech.
Nov 27, 2008 | JVC AV-27D302 27" TV
No picture, but sound
does it work if you connect dish??
Mar 30, 2008 | JVC LT-26WX84 26 in. LCD HDTV
19 in blue screen only sound works great
un plug the tv for 3 minutes to reset it, then plug it back in. if this dont fix it, please get back with me and tell me if you had any power outtages or surges. some times lightning strikes can burn out the tuner when it strikes the cable line.
Oct 19, 2007 | Westinghouse LTV-19W3 19 in. LCD...
MY TV!!
try using AV im puts with dvd or vcr if this work your tuner is bad new cost aruond $90 to 120 if available but next year you wont have use for it
Sep 25, 2007 | JVC AV-48WP74 48" Rear Projection...
Blue Screen
Sounds Like Bad Tuner,Try Running Audio Video Jacks in,Also Replace your Cable wires ttech
Jul 29, 2007 | Mitsubishi WS-55313 55" Rear Projection...
JVC 36 inch televivision i bouhgt it about 6 years ago
The lightning probably zapped the tuner in you set. If no signal is present the screen is muted (BLUE).This is a feature to prevent your seeing snow on the screen. Stargazer
Jun 14, 2007 | JVC TM-2703SU 27" TV
No Picture
As long as you can hook that same cable up to a different TV and get a good picture, you must have somehow damaged the tuner on the APEX - unless the set was mishandled while moving. Those cheaper brands won't take much punishment.
Jan 20, 2007 | Apex Digital AT2008S 20" TV
Delay with channel surfing
Two things I would check before contacting JVC. In the on screen menu does it have a setting under tuner controls to disable AFC? It sounds like the tuner is seeking the proper channel frequency before it locks it in and displays a picture. If there is no such setting, then I would try a channel autoprogram in the cable mode. I'm assuming you have no cable or satellite TV box hooked up to the set. JVC is usually a pretty good brand name.
Dec 19, 2006 | JVC AV-32F476 32 in. Television
Televison & Video Logo
48 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
