Question about Mitsubishi VS-4544 45" TV
Mitsubishi 52" Sound Fluctuation
Our tv about 8 -10 years old and the sound fluctuates. For a day or 2 the volume will be all the way and you can barely hear it, all of a sudden the sound slowly starts to rise and within a couple minutes it is very loud, everything will work fine for a day or two and then the volume drops off again. Also we notice that when the volume is not working, the top of the picture screen appears jittery, when the volume comes back, the screen is crystal clear.
jomaru
  • 337 Answers
SOURCE: picture faded to black, came back, faded again and had stayed black.
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Posted on Oct 11, 2006
  • 87 Answers
SOURCE: Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Posted on Nov 05, 2007
SOURCE: Black screen and no sound
I realized that there is a 90 day warrantee on parts and a 30 day limited warrantee on labor for the  repairs that were done. As I stated, the original problem was the picture shrinking after a few minutes of the set being on. The repair firm took my control board with them. When they came back to install the repaired control board in my set there was a load spark during the installation, after which I had a black screen and no sound.  The repair firm took my set them and installed a "CAP Kit", a STRM6511, and a "D1881". The set worked perfectly until two days ago.
I called the repair firm an they are coming out this Thursday to check out my TV.   I am hoping the problem is related to the failure of one of the parts installed to fix a similar problem which occurred after the sparking incident.
Posted on Apr 01, 2008
Slinteriors
  • 8617 Answers
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Posted on Jun 15, 2008
SOURCE: Mitsubishi WS-55807 TV won't turn on
I have the same problam,I got this tv for free and i am trying to find out what is wrong with is so i can fix it.has any of yall got yalls fix if so what did you do to get it to work.
Thanks
Dustin
Posted on Jul 01, 2008
I have a 52" mitsubishi
go into the menu and go to audio/video should be able to set your audio from there
Dec 11, 2010 | Mitsubishi Televison & Video
Can't find it under the hardware. there's nothing but static, i can mute it and change volume
Hardware failure, Your sound card chip may be burnt due to voltage fluctuation. Get a PCI sound card and fix it.
Nov 29, 2010 | Computers & Internet
Vizio tv seems to have trouble with volume certain ch fox and ch 8 need to increase volume a lot also goes black loses sound g Have dishnetWork does true sound have to be off
It would be our pleasure in assisting you with that. We would recommend using our Volume Leveling feature which is available on our ViP222k, ViP612, ViP722k, and ViP922 receivers. Volume Leveling keeps the volume levels consistent between programming and commercials and prevents drastic volume level changes when watching television between HD and SD channels. Start by pressing the "Menu" button then pressing 6 for "System Setup" then 7 for "Audio Output". Select "Enable" below "Volume Leveling" then select "Done" to save these settings. If you're using a ViP922 receiver from the main menu select "Settings", select "Audio Output", and then enable Volume Leveling. This should help with the volume fluctuation issue you have been having. Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 25, 2010 | Vizio L37 Television
Extreme fluctuation of TV sound leval drives me nuts!!!!
arn't all french movies in whisper and dark screen mode?
I suggest using an amplifier ( yes an amp) reduce the volume on TV to just audible and plug in xtension line to an amp and set the volume on it. It is probably a faulty sound board in your unit. The use of an external amp will control it better by the audio out line.
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Transparent French TV Commercials, Volume...
Sound volume fluctuates
gah im having same problem with my creative 5.1s... took it apart and used contact cleaner on every bit of soldering i could see, and checked the wire... still no luck
Sep 27, 2008 | Logitech X-540 Computer Speakers
60" Mitsubishi TV - Approximately 6 years old
Good Day;
Try resetting the TV and any BOX by unplugging both for @ to 5 minutes then plug back in.
Good Luck, big IRISH.
Aug 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
