Question about Plumbing
Rusty water after installing a water filter?
I recently installed a Whirlpool, model WHKF-DWHBB, water filter unit in my home and I still have rusty water. I live in a home with a well and have a Kenmore, Ultrasoft 180, water conditioner. I have these units plumed from the pressure tank into the conditioner and then into the filter. Should I reverse the position of the filter and the conditioner?
  • Chris Ballard
    Chris Ballard May 11, 2010
    What type of piping do you have past the filter? Galvanized steel is prone to rusting inside and would'nt be filtered.
  • 68 Answers
Leave it like it is. Unless you had sand coming through your water. The softener will regenerate and rinse alot of what your filter would plug with down the drain,
Please rate this response and Good Luck, Phil
Posted on Dec 31, 2008
Have you heard of the Merus ring ? It has been installed on a 26,000 sq ft office building in fresno which had a very severe rusty water problem.and in a very short period of time solved the owners problem at a reasonable cost see www.merusca,com for more info. Rick W
Posted on Feb 12, 2010
Whirlpool side by side has low pressure with filter, works great without.
more than likely the saddle valve...the valve you or the plumber installed to tie into the water line and shut it off for filter install. it's getting clogged up. Turn it all the way off and on again 3 or 4 times this should clean out the little hole feeding thru the valve from the pipe.
hope this helps.
take a look of a saddle valve.
Jan 25, 2018 | Whirlpool Refrigerators
Where is the water filter on whirlpool model ED27PQ?
According to the information you gave, you have no factory installed filter in this unit. However, in this case, most people would have installed a water filter in the water line itself to the unit. Although it is possible to filter the water for this unit, Whirlpool did not sell this model with a internal filter. I hope this helped.
Jun 29, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
although this unit not equipt from factory with water filter,an add on can easily by installed. many different "in-line "water filter options are available, depending on installation, a filter can go either behind the refrigerator, or just passsed the initial water supply connection
Oct 27, 2013 | Whirlpool W8RXEGMW 17.5 cu. ft....
Have a Pentair 7000 water softener, getting brown/gray water in my home! Any suggestions
I think this can also be due to rusty pipes or connections as it is seen to clear off after the initials flow. You can connect an online filter unless the water is confirmed to be hard and needs to be softenend..
Jun 26, 2012 | Washing Machines
I have a GD22DQ model side by side whirlpool gold refrigerator. we have looked through the manual and we cannot find were to put the water filter. the manual shows a dial at the bottom of the fridge but...
Hello Dollar1392,
I understand that you can not locate the water filter for your unit. If you have a water filter in your unit it will be located in one of two locations at the bottom of the unit in the grille or in the top of the refrigerator section on the right side in the rear corner. If the filter is not located at one of these locations then there is no filter on your unit. You will need to put an in-line filter in your water supply line.
Thank you for choosing if you have any further questions please post back to the thread.
Apr 23, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
I would like to know where I can find the installation instructions online a whirlpool whole house water filter whkf-dwhbb
You have actually posted on the washing machine forum!
You will need to type into your search engine/web browser 'whirlpool whole house water filter' and, with a bit of luck,you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct. You may find, however, that it will supply only to service engineers but good luck anyway.
Good luck,
John C.
Please score this solution accordingly- thanks!
Apr 10, 2011 | Washing Machines
Where the water filter whirlpool gold model no GS6SHEXMQ00 located? the last home owner lost the manual.
The base grille water filter cartridge is located below the freezer
compartment door. Depending on your model, you may have a
filter that is installed behind the base grille or a filter that
is installed through the base grille
This should be the right manual
Mar 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Stomach pain drinking from refrigerator water dispenser
Get a charcoal filter from home depot (about 50.00) and install behind refrig or in cabinet . Filter has replaceable cartridges like for charcoal , lime , calcium . Installs in supply line to refridg . Do not recommend the 11.00 filter installed in line , where you replace the whole filter . Get the replaceable cartridge type .
Jul 20, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Try to find out if this unit needs a filter for the icemaker
Your refrigerator will not accept nor was designed to use a whirlpool water filter. No a filter is not required. Yes an in line filter can be installed prior to the connection at the inlet valve if you desire.
Apr 02, 2009 | Whirlpool ER6AHKXPQ Top Freezer...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Plumbing Logo
821 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
