How to replace the front passenger window ( not the side mirror the actual window) for 2000 Chrysler Cirrus
SOURCE: Have to replace the glass
JUST MAKE SURE BOTH AREAS R CLEN AND YOU SHOULD BE ABLE TO GO TO ADVANCE AUTO PARTS TO GET GLUE OR A WINDOW PLACE
SOURCE: 2005 Chrysler 300 power mirror passenger side
Unlikely a 'short,' those cause blown fuses and smoking wires.
The switch may be flaky and not contacting as it should when operated and this failure mode is called an 'open.'
Not knowing exactly how the switch is constructed nor mounted, I can't tell you how how to access it.
Many switches have expansion struts on their sides that may lock or notafter being pressed in, but using care, you might try with two butter knives you don't give a hoot about, one to slip the tip under an exposed bezel (if it has one) and the other to place under the first so when you pry by rocking the top knife back and forth, the area under and around the switch doesn't get damaged from the prying.
If you can remove the switch assembly and pull it slightly out of its hole, remove the plug or plugs and reconnect them several times to 'wipe' the surface of the connector(s). Sometimes the crappy plating on connectors just stops conducting from oxidation.
If the switch is constructed so that some 'tuner (or contact) cleaner' (from an electronics store) can be forced into the innards of the switch, you may be able to restore function.
I don't think it is a fuse problem as there is probably one fuse which services multple devices but it could be a failed motor.
SOURCE: How do I change the battery on a 2000 Chrysler
Yes, thats it. Once those are done, you are there. Be sure to use a quality battery, you dont want to go cheap and have to replace it again.
