Question about Sony Cyber-Shot DSC-S85 Digital Camera
When camera is turned on it makes several beeping noises then turns off when i turn my camera on, it keeping beeing, then it turns off, whats's wrong with it and what should i do?
  • 489 Answers
Hi
Whats happening is there is some sort of problem with the lens, it could happen in many different ways such as sand or dirt in the lens gears or impact damage.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Sony (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
Hope this helps,
Thomas
Darntoothysam com
Posted on Oct 21, 2008
Blurry pictures and beeping noises
It could be the lens is damaged on the inside (Gears and so).
But before you make any conclusion. try to switch the camera to auto mode and make sure the camera is not in the macro mode.
To start, switch of the camera, remove the batty and leave it out several seconds. perhaps you also should charge the battery on an external charger,but if you are sure it is charged, after a few moment reinsert the battery. Then switch the camera to the automatic mode and check if it is not in Macro. (when you see the flower on the screen it is in macro)
If it is still acting the same you made the right conclusion in the question above. (I hope you are wrong but if not, you start looking for another camera)
Jan 26, 2014 | GE J1470S Digital Camera
When i turn my camera on it makes some noise. Until i shake the camera, noise disapeare, but it could come againe at any time...
The hardware inside is defective. You will need to replace the camera either by warranty or buy a new one. Make sure you save your pictures!
Jan 08, 2014 | Panasonic Lumix DMC-TZ1 Digital Camera
My Packard bell pc won't turn on an keeps making a
The number and timing of beeps will tell you what's wrong. You'll have to find the motherboard manual to find what the beeps mean though. Would be worth taking the RAM chips out, blowing any dust away and putting them back in.
Apr 20, 2012 | Computers & Internet
My Olympus Camedia C-750 will not turn on. When I start it, the screen looks normal but then goes blank. it stays lighted and then beeps several times then makes a noise like a picture has been taken,...
If those batteries are definitely good then the electronics of unit have gone haywire. Contact Olympus to see if there is some sort of hidden code to reset electronics to factory defaults.
Sep 05, 2017 | Olympus Camedia C-750 Ultra Zoom Digital...
My camera keeps turning off with a full battery and makes a beeping noise
There is something obstructing the lens. Camera turns off if it can't extend and retract the lens. Turn it downward, try blowing compressed air around the lens itself, or if all else fails spraying around the base with a light dusting of CRT cleaner (90% isopropal alcohol spray)
Apr 30, 2010 | Samsung L100 Digital Camera
Beeping sound when starter is turning over for the
Have u replaced the spark plugs? Is this the beeping noise you hear when you first turn your key over the same as past times you have started the motor? It just keeps going though right? I would make sure you have the right level of fluids and make sure your fuel pump works, fuel filter isn't clogged and plugs and wires are in good shape.
If that is all good then you might have a bad coil pack. Test it and make sure you are getting correct voltages, if not then replace it.
Also did you winterize your motor after the last time you used it? If not you could of cause some internal damage to the motor.
Good Luck,
Subikid90
Mar 04, 2010 | Boating
Sr.1320nx will not start. makes a beeping noise.
could be a memory failure or a hardrive failure remove every thing pluged into back liek keyboards cameras printers mouses and try turn it on, try run a dinostic cd you might have it with your pc and it will tell you what problem is, or it could even be a hard drive failure. you can try removing memory dimms one at time and each time try to start it up.
Nov 28, 2009 | Computers & Internet
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Reoccuring beeing
go to settings then to audio then to alert tones turn the volume down and that will fix it
Aug 15, 2009 | LG CE110 Cellular Phone
No 3 beep notification in the earpiece of an incoming call
I had the same problem and the cause was the handset lifter and not the earpiece--if the ringtone is too low at the lifter, it won't be detected and transmitted to the earpiece. Cranked up the ringtone and everything is fine.
If that doesn't take care of the problem you might look at whether or not you're using custom ringtones which might cause a problem. Switch them back to the defaults and see if the problem goes away.
Nov 28, 2007 | Plantronics CS70 Wireless Headset
Sony Cyber-Shot DSC-S85 Digital Camera Logo
43 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
