Question about Philips GOGEAR SA6045 MP3 Player
Go gear 4 gb turns on thean says
Same as above, i pluge it in to the computer, and the screen comes on and says "do not disconect" then it says "ok to disconect" the screen stays on for a little bit then goes off . then when i start it up it does what i said in the subject line
  • 8,596 Answers
Sounds like normal behavior to me. It only gives you menu, playback when it is DISCONNECTED fro mthe computer.
Posted on Jan 01, 2009
I replaced my 97 s10's fuel pump checked the fuses &checked the relay & reset my computer changed my fuel filter disconected my security system & still can't get my fuel pump to co
The oil pressure sending unit could be bad. If your oil pressure gets below 7psi than it shuts off all power going to the fuel pump. It is screwed into the engine block just to the right of the distributor.
Oct 13, 2012 | 1998 Chevrolet S-10 Pickup
My 1994 camry horn isn't working fuses ok help
check the reley and the horn is pluged in also it might even be in the styering wheel that the wire is disconected if you had an air bag deployment
Dec 09, 2011 | Cars & Trucks
Cooling fan runs as soon as the engine starts and check engine light is on. its a 1995 subaru impreza
No idea...don't work on them much. I suggest that you get either a haynes or chilton manual to guide you through testing (and manual will help you with many more items while you have the car) Generally the sensor is close to a main water passage on the intake manifold or cylinder head. Most systems operate the same way: sensor sends info to computer which in turn sends a signal to the relay that operates the fan. Generally when there is a problem such as yours, most often it is the relay that has burned closed that keeps the fan on but I always include the sensor in testing to eliminate the one time that it trys to fool you.
Aug 05, 2009 | 1995 Subaru Impreza
My Ipod 3rd gen. wont work other than when its pluged into the pc
Your battery is most likely dead to the point where it can no longer hold a charge, which is the reason that when you unplug it from the computer, it dies instanly. Batteries are pretty cheap going up to about as high as $25 and if you get it done at a ipod place, installation should not be that much.
Aug 05, 2009 | Apple iPod nano 8 GB Pink (3rd Generation)...
The freezer gets warm thean freezes than gets warm
if its an anti frost one it might think its freezin up probly something wrong with the thermostat
Jun 08, 2009 | Frigidaire FGB24S5A Gas Single Oven
Ipod 30 gb next gen.nothing but a black screen
I would suspect either a bad screen, or a bad battery. Can you hear the hard drive turning? Put it next to your ear and see if you hear a whirling sound. If you can hear that, then your screen is gone and needs to be replaced.
Try plugging it into a wall charger. If it comes on then it is the battery. The computer often does not have enough power to make it light up if the battery is really bad. Hope that helps.
Dec 12, 2008 | Apple iPod MA446LL/A MP3 Player
My ps3 won't play GTA 4 and Metal Gear Solid 4
This is what used to happen to me on my ps3 slim 160 GB when I put the disc in the screen goes black and int he top left corner I have a flashing disc, i updated the system to FW 4.00 and now the game works fine, i was previously running FW 3.73.
Oct 30, 2008 | Sony Playstation 3 (PS3) Console
Wont charge new battery
maybe your new battery is messed up
Apr 07, 2008 | Apple iPod nano 3rd Generation
Philips GOGEAR SA6045 MP3 Player Logo
167 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
