Question about Orion STV2763 27" TV
Monitor problem theres a space at the top of the monitor of the stv2763 thats acting like a mirror of the image on the screen. whats going up on the screen is in this small space going down. its not blocking the that part of the screen but both images are showing. there are horizontal lines in this part of the screen. its a mirror effect.
  • ivlan Mar 18, 2008
    Yes, I had the same problem for about a year, it didn't block the image so I kept on using the tv on a regular basis, but yesterday it finally did it. The TV screen shut-out completely, leaving just a black screen with a white line in the middle, I took the back cover off to see what was going on, the main board it's burned, looks like it burned a resistor a couple of diodes, and a couple of transistors, so it's pretty much trashed, so now I'm looking to see if I can find the main board so I can replace it, I like it, last me three years so if I can fix it I will. if not I'm going LCD....
    Novelist:
    Champion:
  • 275 Answers
I agree with Techman. Nothing you can do at home. ask for professional help
Posted on Jul 07, 2006
    President:
  • 3,130 Answers
This sounds like a verticle foldover problem . This could be as simple as a defective wave shapper capacitor or could be the main vert. sweep IC also. All these parts are soldered in so if you have no experience with this stuff please seek profesional assistance with this repair Good Luck
Posted on Jul 06, 2006
Can my Nikon D50 be fixed or do I need to send it for repair?
This happens during malfunction of mirror and shutter.that is when cliked shutter opens but mirror did not go up so blank monitor screen hence no image in card. Take to skilled technician to replace shutter loader mechanism.
Apr 25, 2016 | Nikon D50 Digital Camera
To widen border on Toshiba lap top
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.If you cannot change the screen resolution then most likely the incorrect video driver has been installed.
Mar 30, 2012 | Computers & Internet
I am using a MacBook with an Acer Monitor with a mini connection. The monitor shows the start up screen of the MAC but known of the icons nor does it reflect what is on the MacBook while I am working.
This is a very simple solution, fortunately. The default behavior of an external monitor connected to a portable Mac is to act as extra space, effectively extra screen "real estate," where you can move windows or do whatever else you need to.
Verify this by moving your mouse to the right-hand side of your screen, and then keep going - you'll see your mouse appear on the external monitor.
If you want to have the external monitor reflect exactly what you are doing on the primary monitor, simply go to Apple menu > system preferences > displays > arrangement and check 'mirror displays.'
And that's all there is to it!
May 21, 2011 | Acer AL1913 19" LCD Monitor
I run on Windows XP, pack3 and I use a CRT ViewSonic EF70 ... 17 inches The screen is not filled completely with the image from Microsoft Internet Explorer, nor with Outlook Express .... there is about 3...
two things you can do, first right click on your windows screen and look for "settings" this will open a dialog box where you can set the screen resolution. Set it lower and see if your screen is now filled. if that doesn't work go into the monitor setup (buttons on the bottom or side of the monitor) and try to set the verticle and horizontal size, since its only 3/4 of an inch you should be able to stretch the screen to fill up the space.
Mar 11, 2011 | ViewSonic E70f 17" CRT Monitor
Hook netbook to tv with rca cables
after hooking it the TV we need to toogle to the external monitor.
Presentation or mirrored display mode
  1. Right-click an empty space on the desktop, and select Personalize .
  2. Select Display Settings
  3. When the New Display Detected dialog box appears, the images on both of the displays will be automatically mirrored.
  4. (Optional) To adjust the resolution, so that the display area of the monitors are the same size in the Display Settings window, select a monitor and slide the resolution slide bar. Click OK to save the setting and exit.
The computer is now ready to display the same screen on all output devices, from monitors to projectors. Press the fn and f4 function keys at the same time to switch the image from the notebook display, to the external monitor, or to both. Extending the desktop
  3. Select the monitor representing your second display. Click the Extend the desktop onto this monitor checkbox and click OK . NOTE: To help identify your monitors, click Identify Monitors . The numbers 1 or 2 are shown on the monitor icons to help you identify them.
  4. (Optional) To adjust the resolution, in the Display Settings window, select a monitor and slide the resolution slide bar. Click OK to save the setting and exit.
  5. (Optional) To change the direction the desktop will extend (left or right to match how the displays are physically set up), select a monitor and drag it to the desired position.
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have a 32 inch screen that is getting lines
This is a problem with the vertical circuit and is likely to be a bad cap in that circuit. It is either a 47ufd or 100ufd 50V cap that is leaky (in an electronic sense). There are potentially dangerous high voltages present inside the set even when unplugged, so a DIY repair without prior experience is not suggested. Expect a parts cost in the $5-$10 range for this repair.
Dan
Mar 03, 2010 | Toshiba 32A33 32" TV
Aspire 3004wlci will not switch to DATA PROJECTOR. Only has auxilary monitor function, allows moving images right to extra screen but Fn 5 button does not switch to monitor Whats the fix?
This can be fixed by going into the graphic card properties.If you have an intel GMA graphics accelarator .You have to go into its properties from the control panel.There are basically two options under it which you can set to desktop clone or mirror image to get the same image you get on the lap screen on with that on the projector.
Oct 23, 2009 | Computers & Internet
Hooking up a second ACER monitor as an extended desktop
I have 2 acer AL2016W's and have the same problem. The earlier ones with the VGA only are the problem from what I can see, they just don't play nicely with the video card for some reason.
First, on your main monitor, click "Show displays in menu bar" on your monitor control panel. This will let you set the resolution for each monitor from the main one, click on the little monitor icon on the top right screen to do this.
If that doesn't work try this:
Connect one acer as the main monitor and one crappy vga crt monitor as the second.
Set mirrored desktop in the system preferences so that the crappy CRT is displaying the exact same resolution as the acer. (1680x1050 59.9Hz)
Disable mirrored desktop. You should now have an acer and a crappy CRT both running 1680x1050 in extended desktop mode.
Shut down, reconnect the acer in place of the crappy CRT.
This should "trick" your video card into having the right resolution, otherwise you'll just get the stupid "input not supported" screen, with no ability to auto configure or use any of the built in controls.
Nov 20, 2007 | Acer AL2016W 20" LCD Monitor
Screen image display distortion
Hello.
What you are reporting is a problem in the pincushion circuit in the horizontal section of your CRT monitor. Usually this is from an electrolytic capacitor that is no longer willing to play nice with all the other components.
It is repairable, but get an estimate first. If the repair bill appears to be around $100, you would be better off to put a few more dollars with that and buy an LCD TFT monitor.
If you are quoted $25 or $30, it is probably worth having repaired. Just keep in mind that these older CRT monitors have age on their components, and once repaired, it will still be an old monitor.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
I hope this helps.
Nov 06, 2007 | Apple Multiple Scan 1705 Monitor
Off center screen
on the computer there is a button called menu press it. use the position tool and put both of them equal eg 50-50
Aug 13, 2007 | Smart Modular PYXSCAPE SV1170 17" Flat...
Orion STV2763 27" TV Logo
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
